Ga door naar hoofdinhoud
OnePlus 6T Screen Replacement
Wat je nodig hebt
  1. OnePlus 6T Screen Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6T Screen Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6T Screen Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6T Screen Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Screen Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Screen Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6T Screen Replacement, Speaker: stap 5, afbeelding 1 van 1
    • Remove seven 3mm Phillips #00 screws from the speaker.
    Vraag FixBot
    Voeg opmerking toe
  6. OnePlus 6T Screen Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to lift and remove the speaker.
    Vraag FixBot
    Voeg opmerking toe
  7. OnePlus 6T Screen Replacement, Battery and Screen Connectors: stap 7, afbeelding 1 van 3 OnePlus 6T Screen Replacement, Battery and Screen Connectors: stap 7, afbeelding 2 van 3 OnePlus 6T Screen Replacement, Battery and Screen Connectors: stap 7, afbeelding 3 van 3
    • Remove all visible screws securing the housing above the battery
    • Insert a pick or a spudger by the silver slot on the left. Along the phone's edge, gently pry up until the housing is released.
    • This should easily release. If not, check to make sure all screws have been removed (check under stickers)
    • Disconnect the battery from the phone by lifting the battery connector from the phone with a spudger.
    • Do not use a metal tool to disconnect the battery to avoid shorting it.
    • Using a spudger, disconnect the screen by carefully lifting the screen connector.
    Vraag FixBot
    Voeg opmerking toe
  8. OnePlus 6T Screen Replacement: stap 8, afbeelding 1 van 2 OnePlus 6T Screen Replacement: stap 8, afbeelding 2 van 2
    • With a swab or q-tip, apply alcohol to the sides of the broken screen to soften the adhesive that holds the screen on the phone.
    • You may find that the alcohol is not strong enough to fully loosen the adhesive on the phone. To remedy this, you can apply heat to the edges of the phone with either a hairdryer or iOpener.
    Vraag FixBot
    Voeg opmerking toe
  9. OnePlus 6T Screen Replacement: stap 9, afbeelding 1 van 1
    • Press a suction cup against the display.
    • Glide a spudger around the screen edge until all of the adhesive glue is broken.
    Vraag FixBot
    Voeg opmerking toe
  10. OnePlus 6T Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the display from the phone.
    • ALWAYS remember to thoroughly and gently clean the surfaces and remove any and all remaining or leftover old adhesive. this is a crucial step in assuring that your new adhesives "bond" properly and securely to provide adequate adhering, as well as to keep any dust or dirt and other undesired subjects from entering the device.
    • Using B7000 Adhesive, carefully place a thin layer of glue around the edges where the old screen used to be. Carefully place the new OnePlus LCD and Touch Screen into place. This may take a little adjusting but the screen should fit perfectly into place. Apply pressure along all the edges to secure the screen in place.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
25 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
skipped a step removing the plate around the camera. It should be after step 6 and before step 7.
otherwise this guide is meh. its okay. it gets the job done, I guess.
Billieving - Antwoord Deel
I only have a broken front glass on my 1+6t the screen seems ok what differences are there and where do I get a good quality front glass for it. I have never disassembled a phone before but I know a bit about electronics and know how to put computers together and I don't think it is worth me paying a third of the phon's cost for a whole screen and/or pay someone to repair it
ZAHID SHABIR - Antwoord Deel
Step 7 is too complicated. Just remove the metal thingy above the battery connector and pull it up carefully.
Else its a good guide
Pie - Antwoord Deel
step 9 was kinda implossible for me, even though i used alcohol and heat before.. had to dig my Jimmy under the broken corner (top left), cracked some of my screen and was somehow able to lift the screen far enough to get under it.. im also missing some detailed instructions of the reassembly, had to watch a video for this
Raygin - Antwoord Deel
My phone fell down and has a black screen. The screen has no cracks at all. And the phone is working too as I am able to hear the notifications and incoming calls. So any idea how much it would cost to repair it?
Ishwari Khalate - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 203
Altijd: 32,355
