Inleiding
If your OnePlus 6T back cover is damaged or scratched, or you need to access the internal components of your phone, follow this simple guide to remove the back cover.
Before you begin, make sure that your phone is powered off and unplugged from the charger.
Wat je nodig hebt
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
19 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
I wonder if this is the same for OnePlus 6 (6000/6003)?
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Preciso de uma tela para o one plus 6t
Tela one plus 6t quem sabe onde ou se alguém vende
