Ga door naar hoofdinhoud
OnePlus 6 Motherboard Replacement
Wat je nodig hebt
  1. OnePlus 6 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6 Motherboard Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6 Motherboard Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6 Motherboard Replacement, Fingerprint sensor: stap 5, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement, Fingerprint sensor: stap 5, afbeelding 2 van 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    Vraag FixBot
    Voeg opmerking toe
  6. OnePlus 6 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. OnePlus 6 Motherboard Replacement: stap 7, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
John Steven Trammell
961 Reputatie
4 handleidingen geschreven
Clemson, Team 4-3, Hunter Fall 2021 Lid van Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Leden
28 handleidingen geschreven
1Gids Commentaar
Can you repair my One plus 6. It's one IC of motherboard is damaged.
AMIT PANWAR - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 121
Altijd: 5,602
