Ga door naar hoofdinhoud
OnePlus 6 Midframe Replacement
Wat je nodig hebt
  1. OnePlus 6 Midframe Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6 Midframe Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Midframe Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6 Midframe Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Midframe Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6 Midframe Replacement, Battery: stap 4, afbeelding 1 van 2 OnePlus 6 Midframe Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6 Midframe Replacement, Fingerprint sensor: stap 5, afbeelding 1 van 2 OnePlus 6 Midframe Replacement, Fingerprint sensor: stap 5, afbeelding 2 van 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mickenzie Thompson
373 Reputatie
3 handleidingen geschreven
Clemson, Team 4-3, Hunter Fall 2021 Lid van Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 77
Altijd: 3,526
