Inleiding
Use this guide to replace your heating element if it has stopped working.
Wat je nodig hebt
Firmly grip the extractor head and slowly lift vertically to remove from the device.
First, place the device on its side, making sure the switch is not facing down.
Remove the eight 12mm Phillips #02 screws from the base.
Locate the tie strap holding the wires and cut with a pair of scissors.
Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
Remove the metal housing.
Één andere persoon heeft deze handleiding voltooid.
2Gids Commentaar
Where can I buy a replacement heating element?
For the heating element, the grate popped off. What silicone is used to keep the parts together? Same for the springs inside the white tubes.
