Ga door naar hoofdinhoud
How to rewire a Nostalgia Electrics PCM805
Wat je nodig hebt
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: stap 1, afbeelding 1 van 2 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: stap 1, afbeelding 2 van 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: stap 2, afbeelding 1 van 3 How to rewire a Nostalgia Electrics PCM805: stap 2, afbeelding 2 van 3 How to rewire a Nostalgia Electrics PCM805: stap 2, afbeelding 3 van 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: stap 3, afbeelding 1 van 2 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: stap 3, afbeelding 2 van 2
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: stap 4, afbeelding 1 van 3 How to rewire a Nostalgia Electrics PCM805: stap 4, afbeelding 2 van 3 How to rewire a Nostalgia Electrics PCM805: stap 4, afbeelding 3 van 3
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
Eindstreep
Carlton
672 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-5, Hickman Winter 2015 Lid van USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Leden
8 handleidingen geschreven
Één opmerking
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 686
