Ga door naar hoofdinhoud
Nook BNRV300 Power Button Replacement
Wat je nodig hebt
  1. Nook BNRV300 Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Nook BNRV300 Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Nook BNRV300 Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    Vraag FixBot
    Voeg opmerking toe
  2. Nook BNRV300 Power Button Replacement: stap 2, afbeelding 1 van 1
    • Using your fingers, take off the power button.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
2Gids Commentaar
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Antwoord Deel
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 1,411
