Inleiding
Use this guide to replace the charging port assembly in your Nokia G310 5G.
Note: The Nokia G310 5G's charging port assembly is a daughterboard that includes both the USB-C charging port and the headphone jack.
Wat je nodig hebt
Power down your phone and unplug any cables.
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
Press firmly to eject the tray.
Insert an opening pick under the small notch in the SIM card tray slot.
Position the opening pick at a steep downward angle between the back cover and the screen assembly.
Slide the opening pick down the left edge of the phone to release the plastic clips.
With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
Lay the back cover next to the phone.
Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
Remove the back cover.
Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
Insert an opening pick under the right edge of the motherboard cover.
Twist the opening pick to release the plastic clips.
Use a pair of tweezers or your fingers to remove the motherboard cover.
Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the eight 3.8 mm-long screws securing the loudspeaker.
Insert an opening pick underneath the top right edge of the loudspeaker.
Twist the opening pick to release loudspeaker from the plastic clips holding it in place.
Use a pair of tweezers or your fingers to remove the loudspeaker.
Use the flat end of a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Use a spudger to disconnect the antenna cables by prying their coaxial connectors straight up from the sockets on the board.
Insert the flat end of a spudger underneath the top right edge of the charging port assembly.
Pivot the charging port assembly up until you can grip it with your fingers.
Use your fingers or a pair of tweezers to remove the charging port assembly.
Use a pair of tweezers to remove the two black U-shaped rubber gaskets from the charging port and the headphone jack.
Only the charging port assembly remains.
Één andere persoon heeft deze handleiding voltooid.
