Ga door naar hoofdinhoud
Nokia 3100b Microphone Replacement
Wat je nodig hebt
  1. Nokia 3100b Microphone Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your phone is turned off.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 3100b Microphone Replacement: stap 2, afbeelding 1 van 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 3100b Microphone Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 3100b Microphone Replacement: stap 4, afbeelding 1 van 1
    • Retrieve your SIM card.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 3100b Microphone Replacement, Microphone: stap 5, afbeelding 1 van 1
    • Press the black tabs to release the front cover from the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 3100b Microphone Replacement: stap 6, afbeelding 1 van 1
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 3100b Microphone Replacement: stap 7, afbeelding 1 van 2 Nokia 3100b Microphone Replacement: stap 7, afbeelding 2 van 2
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia 3100b Microphone Replacement: stap 8, afbeelding 1 van 3 Nokia 3100b Microphone Replacement: stap 8, afbeelding 2 van 3 Nokia 3100b Microphone Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Sterling Fuentes
139 Reputatie
8 handleidingen geschreven
Cal Poly, Team 29-64, Johann Spring 2010 Lid van Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 2,486
