Ga door naar hoofdinhoud
Nobis NB07 Speaker Replacement
Wat je nodig hebt
    1. Nobis NB07 Speaker Replacement, Opening the case: stap 1, afbeelding 1 van 1
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Nobis NB07 Speaker Replacement: stap 2, afbeelding 1 van 3 Nobis NB07 Speaker Replacement: stap 2, afbeelding 2 van 3 Nobis NB07 Speaker Replacement: stap 2, afbeelding 3 van 3
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Vraag FixBot
      Voeg opmerking toe
    3. Nobis NB07 Speaker Replacement, Replacing the battery: stap 3, afbeelding 1 van 3 Nobis NB07 Speaker Replacement, Replacing the battery: stap 3, afbeelding 2 van 3 Nobis NB07 Speaker Replacement, Replacing the battery: stap 3, afbeelding 3 van 3
      • Remove the tape holding the battery in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Nobis NB07 Speaker Replacement: stap 4, afbeelding 1 van 3 Nobis NB07 Speaker Replacement: stap 4, afbeelding 2 van 3 Nobis NB07 Speaker Replacement: stap 4, afbeelding 3 van 3
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Vraag FixBot
      Voeg opmerking toe
    5. Nobis NB07 Speaker Replacement: stap 5, afbeelding 1 van 1
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Vraag FixBot
      Voeg opmerking toe
    6. Nobis NB07 Speaker Replacement: stap 6, afbeelding 1 van 2 Nobis NB07 Speaker Replacement: stap 6, afbeelding 2 van 2
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Nobis NB07 Speaker Replacement, Removing the speaker: stap 7, afbeelding 1 van 3 Nobis NB07 Speaker Replacement, Removing the speaker: stap 7, afbeelding 2 van 3 Nobis NB07 Speaker Replacement, Removing the speaker: stap 7, afbeelding 3 van 3
      • Remove the tape holding the speaker in its socket.
      Vraag FixBot
      Voeg opmerking toe
    2. Nobis NB07 Speaker Replacement: stap 8, afbeelding 1 van 2 Nobis NB07 Speaker Replacement: stap 8, afbeelding 2 van 2
      • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
      • Look for the place where the speaker's cables meet with the motherboard.
      • Annotate where which color goes to make the reassembly easier.
      Vraag FixBot
      Voeg opmerking toe
    3. Nobis NB07 Speaker Replacement: stap 9, afbeelding 1 van 2 Nobis NB07 Speaker Replacement: stap 9, afbeelding 2 van 2
      • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
      • You can now remove the speaker.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Daniel Gomero
966 Reputatie
5 handleidingen geschreven
USF Tampa, Team 5-5, Brown Winter 2015 Lid van USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Leden
11 handleidingen geschreven
2Gids Commentaar
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - Antwoord Deel
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 564
