Ga door naar hoofdinhoud
Nintendo WaveBird Wireless Controller Joystick Replacement
Wat je nodig hebt
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: stap 1, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: stap 2, afbeelding 1 van 1
    • Remove both batteries from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: stap 3, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: stap 3, afbeelding 2 van 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: stap 4, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement: stap 4, afbeelding 2 van 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 1 van 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 2 van 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: stap 6, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: stap 6, afbeelding 2 van 2
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Garrett Leung
979 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
37 handleidingen geschreven
1Gids Commentaar
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 114
Altijd: 11,492
