Ga door naar hoofdinhoud
Nintendo WaveBird Wireless Controller C-Stick Replacement
Wat je nodig hebt
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: stap 1, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: stap 2, afbeelding 1 van 1
    • Remove both batteries from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: stap 3, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: stap 3, afbeelding 2 van 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: stap 4, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller C-Stick Replacement: stap 4, afbeelding 2 van 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: stap 5, afbeelding 1 van 3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: stap 5, afbeelding 2 van 3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: stap 6, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: stap 6, afbeelding 2 van 2
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Garrett Leung
979 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
37 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 44
Altijd: 3,037
