Ga door naar hoofdinhoud
Nintendo Switch Rear Panel Replacement
Wat je nodig hebt
  1. Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 1 van 3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 2 van 3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 3 van 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: stap 2, afbeelding 1 van 3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: stap 2, afbeelding 2 van 3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: stap 2, afbeelding 3 van 3
    • Continue sliding the controller upward until it's completely removed from the console.
    • Repeat this same process for the other controller.
  3. Nintendo Switch Rear Panel Replacement, Remove the back-side screws: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: stap 4, afbeelding 1 van 2 Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: stap 4, afbeelding 2 van 2
    • Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
  5. Nintendo Switch Rear Panel Replacement: stap 5, afbeelding 1 van 2 Nintendo Switch Rear Panel Replacement: stap 5, afbeelding 2 van 2
    • Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Rear Panel Replacement: stap 6, afbeelding 1 van 2 Nintendo Switch Rear Panel Replacement: stap 6, afbeelding 2 van 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Rear Panel Replacement: stap 7, afbeelding 1 van 1
    • Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
  8. Nintendo Switch Rear Panel Replacement: stap 8, afbeelding 1 van 3 Nintendo Switch Rear Panel Replacement: stap 8, afbeelding 2 van 3 Nintendo Switch Rear Panel Replacement: stap 8, afbeelding 3 van 3
    • Lift the rear panel up from the bottom of the device and remove it.
Conclusie
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
75 andere personen hebben deze handleiding voltooid.
Craig Lloyd
35.418 Reputatie
82 handleidingen geschreven
10 opmerkingen
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - Antwoord
You can transfer the grill to the new back plat
Phillip Norton -
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - Antwoord
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - Antwoord
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 37
Afgelopen 7 dagen: 316
Afgelopen 30 dagen: 1,545
Altijd: 91,760
