Ga door naar hoofdinhoud
Nintendo Switch Power and Volume Button Board Replacement
Wat je nodig hebt
  1. Nintendo Switch Power and Volume Button Board Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 1 van 3 Nintendo Switch Power and Volume Button Board Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 2 van 3 Nintendo Switch Power and Volume Button Board Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 3 van 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Power and Volume Button Board Replacement, Remove the Joy Con controllers: stap 2, afbeelding 1 van 3 Nintendo Switch Power and Volume Button Board Replacement, Remove the Joy Con controllers: stap 2, afbeelding 2 van 3 Nintendo Switch Power and Volume Button Board Replacement, Remove the Joy Con controllers: stap 2, afbeelding 3 van 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Power and Volume Button Board Replacement, Remove the back-side screws: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Power and Volume Button Board Replacement, Remove the top and bottom screws: stap 4, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement, Remove the top and bottom screws: stap 4, afbeelding 2 van 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Power and Volume Button Board Replacement: stap 5, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 5, afbeelding 2 van 2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Power and Volume Button Board Replacement: stap 6, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 6, afbeelding 2 van 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Power and Volume Button Board Replacement: stap 7, afbeelding 1 van 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Power and Volume Button Board Replacement: stap 8, afbeelding 1 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 8, afbeelding 2 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 8, afbeelding 3 van 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Power and Volume Button Board Replacement, Remove the shield plate: stap 9, afbeelding 1 van 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  10. Nintendo Switch Power and Volume Button Board Replacement: stap 10, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 10, afbeelding 2 van 2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  11. Nintendo Switch Power and Volume Button Board Replacement: stap 11, afbeelding 1 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 11, afbeelding 2 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 11, afbeelding 3 van 3
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  12. Nintendo Switch Power and Volume Button Board Replacement, Disconnect the battery: stap 12, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement, Disconnect the battery: stap 12, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  13. Nintendo Switch Power and Volume Button Board Replacement, Remove the heat sink: stap 13, afbeelding 1 van 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  14. Nintendo Switch Power and Volume Button Board Replacement: stap 15, afbeelding 1 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 15, afbeelding 2 van 3 Nintendo Switch Power and Volume Button Board Replacement: stap 15, afbeelding 3 van 3
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  15. Nintendo Switch Power and Volume Button Board Replacement, Remove the fan: stap 16, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement, Remove the fan: stap 16, afbeelding 2 van 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
  16. Nintendo Switch Power and Volume Button Board Replacement: stap 17, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 17, afbeelding 2 van 2
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
  17. Nintendo Switch Power and Volume Button Board Replacement: stap 18, afbeelding 1 van 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 4.8 mm screws securing the fan.
  18. Nintendo Switch Power and Volume Button Board Replacement: stap 19, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 19, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
  19. Nintendo Switch Power and Volume Button Board Replacement, Power and Volume Button Board: stap 20, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement, Power and Volume Button Board: stap 20, afbeelding 2 van 2
    • Use a spudger to flip up the small black locking flap on the power/volume ribbon cable ZIF connector.
  20. Nintendo Switch Power and Volume Button Board Replacement: stap 21, afbeelding 1 van 1
    • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
  21. Nintendo Switch Power and Volume Button Board Replacement: stap 22, afbeelding 1 van 2 Nintendo Switch Power and Volume Button Board Replacement: stap 22, afbeelding 2 van 2
Conclusie
15 andere personen hebben deze handleiding voltooid.
Blake Klein
72.009 Reputatie
50 handleidingen geschreven
8 opmerkingen
Great guide. Just repaired my daughters Switch by replacing power button.
William Flo - Antwoord
I replaced the cable and still have the same issue, volume up button don't work and volume down is volume up, and it's always kn
nem37g - Antwoord
Hi, did you manage to fix it? I have the exact issue
Jaime Casado -
I changed the cable and it works.
Thanks
Jaime Casado -
Great guide. There were a couple of steps I found missing, but the rest of the guide had very similar steps, so just applying the same logic to the mini-boards I had to pull worked perfectly. This guide saved me from having to buy a new switch or pay almost the price of a new one to have it repaired!
Draque Thompson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 389
Altijd: 31,193
