Ga door naar hoofdinhoud
Nintendo DS Lite Wi-Fi Board Replacement
Wat je nodig hebt
  1. Nintendo DS Lite Wi-Fi Board Replacement, Battery: stap 1, afbeelding 1 van 2 Nintendo DS Lite Wi-Fi Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
    Ritchie - Antwoord
    This will be good for mods
    Matthew Bevins - Antwoord
    I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
    whittlegirls - Antwoord
    bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
    Marie-Julie Richer - Antwoord
    Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
    Polaris -
  2. Nintendo DS Lite Wi-Fi Board Replacement: stap 2, afbeelding 1 van 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Wi-Fi Board Replacement, Lower Case: stap 3, afbeelding 1 van 2 Nintendo DS Lite Wi-Fi Board Replacement, Lower Case: stap 3, afbeelding 2 van 2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Wi-Fi Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
    Not mentioned is to remove the jumper/connector below the word "SLOT-2". Case WILL NOT separate otherwise.
    Kayla - Antwoord
    In the separation step below, the third picture show the case with the jumper/connector removed.
    Kayla - Antwoord
    I cannot remove the tri-wing screws.
    Zach Smith - Antwoord
    Same to me. I tried opening the case by force. Broke several parts of the motherboard…
    Leon -
    I can't remove the final tri wing screw in the battery section and it looks like I grinded the screw out too much for any screwdriver to work.Is there anything I can do?
    Quintin Harbin - Antwoord
    From what I know, the only solution is to drill the screw out with a very small-headed drill :/
    Polaris -
  5. Nintendo DS Lite Wi-Fi Board Replacement: stap 5, afbeelding 1 van 3 Nintendo DS Lite Wi-Fi Board Replacement: stap 5, afbeelding 2 van 3 Nintendo DS Lite Wi-Fi Board Replacement: stap 5, afbeelding 3 van 3
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
    Don’t forget to remove the GBA cartridge placeholder before removing the backside
    Cees Jan de Boer - Antwoord
    You forgot to mention to remove the battery compartment Phillips screw.
    nathan lowe - Antwoord
  6. Nintendo DS Lite Wi-Fi Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
    When you reassemble, make sure that you have the volume and power buttons in place, and make sure they are in the right position to line up with the switches on the motherboard. If they are not aligned, you risk snapping off the tiny switches on the motherboard (in which case, you are in for some soldering work).
    Eric - Antwoord
    I should have read the comments first - broke off the power switch because I didn't know about aligning it. No way I can do soldering, guess it's for the dustbin :-(
    Emma -
    Whoops, remembered the power button but forgot the volume slider.
    I'll do it later.
    analbonghits -
    There is no way that the fact you have to line up the volume and power switch toggles upon reassembly is not in this guide. I just carefully followed this guide to replace the shoulder buttons but ruined my DS lite because I didn’t read these (practically hidden comments due to the design of the website) comments and broke the power switch. Thankfully there are 150 million DS I can buy second hand but “repeat the steps backwards” wasn’t sufficient in this repair. And that’s what this website is for.
    [deleted] -
    Watch out with the shoulder buttons. The spring jumped out and I have to clear my entire room to find it ;_;
    Joshu-chan - Antwoord
  7. Nintendo DS Lite Wi-Fi Board Replacement, Trigger Buttons: stap 7, afbeelding 1 van 2 Nintendo DS Lite Wi-Fi Board Replacement, Trigger Buttons: stap 7, afbeelding 2 van 2
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
    Anything after step 7 is unnecessary if having to replace the left or right trigger button(s).
    Nate River - Antwoord
    The second picture does not show the correct configuration of the button spring. It should be flipped. Look at the trigger on the left of the larger image; that is the correct configuration.
    wrekone - Antwoord
  8. Nintendo DS Lite Wi-Fi Board Replacement, Wi-Fi Board: stap 8, afbeelding 1 van 1
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    There is absolutely no need to follow steps 8-13 if like me, all you needed to do was access the face buttons for cleaning/replacement. Once you have unscrewed the motherboard from the front casing you can just flip it up, making sure you take the front screen with it. You will have full access to the buttons and all of their contacts. No need to remove the wifi board and microphone cable, etc. Also, replacing the ribbon cables for the screen is especially frustrating. Avoid taking them out at all costs, if you can.
    James McCarthy - Antwoord
    what is the "etc."?
    Rita Cao -
    For those replacing the bottom screen, you can just skip to step 13 and go from there. No need to remove the wifi board, antenna, etc.
    lowestseries - Antwoord
  9. Nintendo DS Lite Wi-Fi Board Replacement: stap 9, afbeelding 1 van 1
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
    the i was working on had a different wifi connector. i thought a had broken it but the thing underneath it was just to balance it on the motherboard.
    BigD29853 - Antwoord
    Do you have to put back in the WiFi board? As far as I know it does not require it to play games.
    Aiden Harlin - Antwoord
    With the Nintendo servers now off, and all the games are playable without WiFi. That being said, I don’t know what is used for local multiplayer.
    Polaris -
  10. Nintendo DS Lite Wi-Fi Board Replacement: stap 10, afbeelding 1 van 1
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
    I took it apart successfully and I replaced the screen but I've put it back together and it the green light turns on for about 2seconds quiet dim, brighter for about 1 and then it turns off... I then took the wifi board out, and it turned on! What have I done to it and why doesn't it work with it and only without?!
    Brianlewis - Antwoord
    Exact same symptoms for me : on boot up, green light would stay on for 1 second, then shut down. Without wifi, green light would stay on, but blank screens. In fact, it's because on boot up, DS will check if wifi is present, and stop if there is an error. Then, it checks for upper screen, and after that, for lower screen. If one of these is not responding, DS will turn off. I check my cables (upper screen) and DS started again with no problem.
    Alexandre - Antwoord
Conclusie
8 andere personen hebben deze handleiding voltooid.
Matthew Newsom
40.782 Reputatie
67 handleidingen geschreven
3 opmerkingen
So I came across a "Prison edition" DSLite out of the Kentucky DOC It I was told that the wifi card was disabled but I take it apart and see that it is still there pluged in and everything you don't happen to know how to turn it back on do you it is a gift for my little brother and would like the WiFi to work.
Vincent - Antwoord
Question anyone knows what the pin layout of the board
Aaron Darren - Antwoord
Merhaba Nintendo Ds lite da wifi kartı bozuldugunda ekran açılmaması normal mi ds lite a güç geliyor ışıklar yanıyor ama ekran gelmiyor
Boş - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 208
Altijd: 17,428
