Ga door naar hoofdinhoud
Nintendo 3DS Back Cover Replacement
Wat je nodig hebt
  1. Nintendo 3DS Back Cover Replacement, Loosen the rear screws: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Back Cover Replacement, Remove the rear cover: stap 2, afbeelding 1 van 2 Nintendo 3DS Back Cover Replacement, Remove the rear cover: stap 2, afbeelding 2 van 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
Conclusie
19 andere personen hebben deze handleiding voltooid.
David Hodson
155.394 Reputatie
127 handleidingen geschreven
4Gids Commentaar
Anybody know where to buy replacement back covers for this original 3DS model? I’m finding that a lot of used 3DS’s from this era have 3rd party battery packs and the original cover is lost.
CORED3SIGN - Antwoord Deel
Screws stripped what to do?
Joel - Antwoord Deel
Anyone know where to find the ice blue backplate for the original 3ds?
lendy doku - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 108
Afgelopen 30 dagen: 519
Altijd: 36,924
