Ga door naar hoofdinhoud
Nikon D80 Motherboard Replacement
Wat je nodig hebt
    1. Nikon D80 Motherboard Replacement, Main Board: stap 1, afbeelding 1 van 2 Nikon D80 Motherboard Replacement, Main Board: stap 1, afbeelding 2 van 2
      • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D80 Motherboard Replacement: stap 2, afbeelding 1 van 3 Nikon D80 Motherboard Replacement: stap 2, afbeelding 2 van 3 Nikon D80 Motherboard Replacement: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
      • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the back cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D80 Motherboard Replacement: stap 3, afbeelding 1 van 3 Nikon D80 Motherboard Replacement: stap 3, afbeelding 2 van 3 Nikon D80 Motherboard Replacement: stap 3, afbeelding 3 van 3
      • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
      • Remove the back plate that covers the main board.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D80 Motherboard Replacement: stap 4, afbeelding 1 van 2 Nikon D80 Motherboard Replacement: stap 4, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D80 Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
      • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
      • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
      • Disconnect the main board from the two ports on the left by pulling the main board to the right.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon D80 Motherboard Replacement: stap 6, afbeelding 1 van 3 Nikon D80 Motherboard Replacement: stap 6, afbeelding 2 van 3 Nikon D80 Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Using the soldering iron, disconnect the four wires soldered to the main board.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
      • Remove the main board.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon D80 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 3 Nikon D80 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 3 Nikon D80 Motherboard Replacement, Motherboard: stap 7, afbeelding 3 van 3
      • Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
      • Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
      • Gently remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sara Martin
610 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G1, Leahy Fall 2017 Lid van USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 56
Altijd: 4,753
