Ga door naar hoofdinhoud
Nikon D7000 Mirror Box & Viewfinder Replacement
Wat je nodig hebt
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Motherboard: stap 1, afbeelding 1 van 1
      • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
      • Remove the following 5 screws securing the bottom cover to the camera body:
      • Four 6 mm J000 screws.
      • One 8 mm J000 screw (under lens mount).
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 2, afbeelding 1 van 1
      • Remove three 6 mm J000 screws from under the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 3, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 3, afbeelding 2 van 2
      • Gently pull the bottom cover off of the camera body.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 4, afbeelding 1 van 1
      • Remove the following screws from the port area:
      • Two 3.5 mm J000 screws.
      • One 6 mm J000 screw (right above ports).
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 5, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Peel the rear rubber piece off with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 6, afbeelding 1 van 1
      • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 7, afbeelding 1 van 1
      • Pull the eyepiece cover up to remove it.
      Vraag FixBot
      Voeg opmerking toe
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 8, afbeelding 1 van 1
      • Remove two 6 mm J000 screws from behind the eyepiece cover.
      • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
      Vraag FixBot
      Voeg opmerking toe
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 9, afbeelding 1 van 1
      • Open the SD card cover by pushing slightly down with your thumb and sliding up.
      Vraag FixBot
      Voeg opmerking toe
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 10, afbeelding 1 van 1
      • Remove four 6 mm J000 screws that secure the SD card cover.
      Vraag FixBot
      Voeg opmerking toe
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 11, afbeelding 1 van 1
      • Gently pull the SD card cover off.
      Vraag FixBot
      Voeg opmerking toe
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 12, afbeelding 1 van 1
      • Remove the following screws that secure the back case:
      • One 6 mm J000 screw.
      • One 3 mm J000 screw.
      Vraag FixBot
      Voeg opmerking toe
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 13, afbeelding 1 van 1
      • Carefully lift the back case off.
      Vraag FixBot
      Voeg opmerking toe
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 14, afbeelding 1 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 14, afbeelding 2 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 14, afbeelding 3 van 3
      • Disconnect the following two ribbon cables from the motherboard.
      • See our Cable Connector Guide for help with ribbon cable connectors!
      Vraag FixBot
      Voeg opmerking toe
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 15, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 15, afbeelding 2 van 2
      • Remove the following screws securing the left motherboard shield:
      • One 2 mm J000 screw (on the bottom).
      • One 3.5 mm J000 screw (on the back).
      • Be careful of the grounding clips on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 16, afbeelding 1 van 1
      • Gently pry and lift the left motherboard shield off.
      Vraag FixBot
      Voeg opmerking toe
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 17, afbeelding 1 van 1
      • Remove one 3.5 mm J000 screw securing the right motherboard shield.
      Vraag FixBot
      Voeg opmerking toe
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 18, afbeelding 1 van 1
      • Gently lift the right motherboard shield off with the tip of a spudger.
      Vraag FixBot
      Voeg opmerking toe
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 19, afbeelding 1 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 19, afbeelding 2 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 19, afbeelding 3 van 3
      • Disconnect remaining ribbon cables.
      Vraag FixBot
      Voeg opmerking toe
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 20, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 20, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 21, afbeelding 1 van 1
      • Carefully disconnect the red connector with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 22, afbeelding 1 van 1
      • Remove four 3.5 mm J000 screws securing the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 23, afbeelding 1 van 1
      • Gently pull the port side cover away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 24, afbeelding 1 van 1
      • Lift the motherboard off.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Tripod Plate: stap 25, afbeelding 1 van 1
      • Remove four 6 mm J000 screws securing the tripod plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 26, afbeelding 1 van 1
      • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: stap 27, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: stap 27, afbeelding 2 van 2
      • Disconnect black and white speaker cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 28, afbeelding 1 van 1
      • Remove three 6 mm J000 screws securing the image sensor.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 29, afbeelding 1 van 1
      • Carefully lift the image sensor plate out of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Shutter Assembly: stap 30, afbeelding 1 van 1
      • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
      • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 31, afbeelding 1 van 1
      • Remove two 5 mm J000 screws from under the flash.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 32, afbeelding 1 van 1
      • Remove two 3 mm J000 screws securing the front cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 33, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 33, afbeelding 2 van 2
      • Remove the front cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 34, afbeelding 1 van 1
      • Carefully remove the port cover.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 35, afbeelding 1 van 1
      • Deroute the microphone cable.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 36, afbeelding 1 van 1
      • Remove one 4 mm J000 screw from the front.
      Vraag FixBot
      Voeg opmerking toe
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 37, afbeelding 1 van 1
      • Remove one 8.5 mm J000 screw from the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 38, afbeelding 1 van 1
      • Remove the grip carefully.
      Vraag FixBot
      Voeg opmerking toe
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 39, afbeelding 1 van 1
      • Remove one 4 mm J000 screw securing the top case (under right strap hook).
      Vraag FixBot
      Voeg opmerking toe
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 40, afbeelding 1 van 1
      • Remove one 4 mm J000 screw securing the top case (under left strap hook).
      Vraag FixBot
      Voeg opmerking toe
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 41, afbeelding 1 van 1
      • Remove the sticker covering the diopter adjust screw.
      Vraag FixBot
      Voeg opmerking toe
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 42, afbeelding 1 van 1
      • Remove one 8.0 mm J000 screw.
      • Remove the Diopeter Adjust.
      Vraag FixBot
      Voeg opmerking toe
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 43, afbeelding 1 van 1
      • Remove the top case.
      Vraag FixBot
      Voeg opmerking toe
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 44, afbeelding 1 van 1
      • Remove the Black, Yellow, Green cable from the top case board.
      Vraag FixBot
      Voeg opmerking toe
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 45, afbeelding 1 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 45, afbeelding 2 van 3 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 45, afbeelding 3 van 3
      • Remove two 6.5 mm J000 screws securing the viewfinder.
      • Remove the viewfinder cover.
      Vraag FixBot
      Voeg opmerking toe
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 46, afbeelding 1 van 1
      • Remove one 3 mm J000 screw from the bottom left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 47, afbeelding 1 van 1
      • Remove two 6 mm J000 screws from the left of the shutter.
      Vraag FixBot
      Voeg opmerking toe
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 48, afbeelding 1 van 1
      • Remove two 6.5 mm J000 screws from beneath the lens mount.
      Vraag FixBot
      Voeg opmerking toe
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 49, afbeelding 1 van 1
      • Remove two screws from just below and to the sides of the viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 50, afbeelding 1 van 1
      • Remove one 5 mm J000 screw from the top right of the camera.
      Vraag FixBot
      Voeg opmerking toe
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 51, afbeelding 1 van 1
      • Carefully peel back ribbon cable on the bottom left of camera.
      Vraag FixBot
      Voeg opmerking toe
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 52, afbeelding 1 van 2 Nikon D7000 Mirror Box & Viewfinder Replacement: stap 52, afbeelding 2 van 2
      • Remove the left front ribbon cable from top right of circuit board.
      Vraag FixBot
      Voeg opmerking toe
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 53, afbeelding 1 van 1
      • Remove all three wire connectors.
      Vraag FixBot
      Voeg opmerking toe
    25. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 54, afbeelding 1 van 1
      • Separate the shutter assembly from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Mirror Box & Viewfinder: stap 55, afbeelding 1 van 1
      • Pull out ribbon cable from circuit asembly near front left of device.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 56, afbeelding 1 van 1
      • Desolder red & black power leads.
      • Check out our soldering guide for help!
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 57, afbeelding 1 van 1
      • Disconnect ribbon cable at the top right of camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 58, afbeelding 1 van 1
      • Disconnect ribbon cable at top right of camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 59, afbeelding 1 van 1
      • Disconnected ribbon cable at rear right of viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 60, afbeelding 1 van 1
      • Remove the two 5.5mm J000 screws
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 61, afbeelding 1 van 1
      • Remove the 5.5 mm J000 screw.
      Vraag FixBot
      Voeg opmerking toe
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: stap 62, afbeelding 1 van 1
      • Remove the viewfinder from the mirror box assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Thomas Willson
453 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-6, Lancaster Spring 2015 Lid van Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Leden
40 handleidingen geschreven
1Gids Commentaar
now I know why my camera failed,, the motor overheated
sir francis - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 68
Altijd: 13,855
