Inleiding
This guide uses the lens assembly guide to get the camera apart. Once you have finished with the lens assembly, getting to the casing is fairly easy.
Wat je nodig hebt
Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
On the thumb grip, remove the one 4mm PH00 Philips screw.
To reassemble your device or to attach a new lense, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 andere personen hebben deze handleiding voltooid.
