Ga door naar hoofdinhoud
Nexus 9 USB Daughterboard Replacement
Wat je nodig hebt
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: stap 1, afbeelding 1 van 3 Nexus 9 USB Daughterboard Replacement, Rear Case: stap 1, afbeelding 2 van 3 Nexus 9 USB Daughterboard Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: stap 2, afbeelding 1 van 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: stap 3, afbeelding 1 van 2 Nexus 9 USB Daughterboard Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: stap 4, afbeelding 1 van 3 Nexus 9 USB Daughterboard Replacement: stap 4, afbeelding 2 van 3 Nexus 9 USB Daughterboard Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: stap 5, afbeelding 1 van 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: stap 6, afbeelding 1 van 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Geoff Wacker
91.073 Reputatie
89 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,602
