Ga door naar hoofdinhoud
Nexus 9 Antenna Board Replacement
Wat je nodig hebt
  1. Nexus 9 Antenna Board Replacement, Rear Case: stap 1, afbeelding 1 van 3 Nexus 9 Antenna Board Replacement, Rear Case: stap 1, afbeelding 2 van 3 Nexus 9 Antenna Board Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: stap 2, afbeelding 1 van 2 Nexus 9 Antenna Board Replacement, Antenna Board: stap 2, afbeelding 2 van 2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
Conclusie
Geoff Wacker
89.956 Reputatie
89 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,390
