Ga door naar hoofdinhoud
Nexus 5X Rear-Facing Camera Replacement
Wat je nodig hebt
    1. Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: stap 1, afbeelding 1 van 3 Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: stap 1, afbeelding 2 van 3 Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: stap 1, afbeelding 3 van 3
      • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
      • Press in to eject the SIM card tray.
      • Remove the SIM card tray.
      Vraag FixBot
      Voeg opmerking toe
    1. Nexus 5X Rear-Facing Camera Replacement, Rear Panel: stap 2, afbeelding 1 van 3 Nexus 5X Rear-Facing Camera Replacement, Rear Panel: stap 2, afbeelding 2 van 3 Nexus 5X Rear-Facing Camera Replacement, Rear Panel: stap 2, afbeelding 3 van 3
      • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
      • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Nexus 5X Rear-Facing Camera Replacement: stap 3, afbeelding 1 van 3 Nexus 5X Rear-Facing Camera Replacement: stap 3, afbeelding 2 van 3 Nexus 5X Rear-Facing Camera Replacement: stap 3, afbeelding 3 van 3
      • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Nexus 5X Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 4, afbeelding 2 van 2
      • Tilt the opening pick to lift the rear panel a little bit.
      • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
      • Remove the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    1. Nexus 5X Rear-Facing Camera Replacement, Midframe: stap 5, afbeelding 1 van 1
      • Remove the ten 3.6 mm Phillips screws that secure the midframe.
      Vraag FixBot
      Voeg opmerking toe
    2. Nexus 5X Rear-Facing Camera Replacement: stap 6, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 6, afbeelding 2 van 2
      • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Nexus 5X Rear-Facing Camera Replacement: stap 7, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 7, afbeelding 2 van 2
      • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
      Vraag FixBot
      Voeg opmerking toe
    4. Nexus 5X Rear-Facing Camera Replacement: stap 8, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 8, afbeelding 2 van 2
      • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
      • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
      Vraag FixBot
      Voeg opmerking toe
    5. Nexus 5X Rear-Facing Camera Replacement: stap 9, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 9, afbeelding 2 van 2
      • Make sure all the clips are free.
      • Carefully remove the midframe.
      Vraag FixBot
      Voeg opmerking toe
    1. Nexus 5X Rear-Facing Camera Replacement, Battery Disconnect: stap 10, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement, Battery Disconnect: stap 10, afbeelding 2 van 2
      • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Nexus 5X Rear-Facing Camera Replacement, Rear Facing Camera: stap 11, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement, Rear Facing Camera: stap 11, afbeelding 2 van 2
      • Use the flat end of a spudger to pry up the rear facing camera's flex connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Nexus 5X Rear-Facing Camera Replacement: stap 12, afbeelding 1 van 1
      • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
      Vraag FixBot
      Voeg opmerking toe
    3. Nexus 5X Rear-Facing Camera Replacement: stap 13, afbeelding 1 van 2 Nexus 5X Rear-Facing Camera Replacement: stap 13, afbeelding 2 van 2
      • Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
      Vraag FixBot
      Voeg opmerking toe
    4. Nexus 5X Rear-Facing Camera Replacement: stap 14, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use a pair of tweezers to remove the rear facing-camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
11 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
262.271 Reputatie
682 handleidingen geschreven
7Gids Commentaar
Hi! I just replaced the entire screen panel on my Nexus 5x because it stopped working (it flipped 180* the screen and the image it showed was mirrored -- completely impossible to use the phone). I read several reviews describing the same issue and fixing it by replacing the screen panel. Now I'm having issues with the camera. The front camera works, but the back one doesn't. I reopened the phone to check it was plugged in correctly to the motherboard, and it was. Is there a way to figure out if it's the actual camera that's not working or if it has something to do with the motherboard?
Thanks! -MJ
mariajrodriguezotoya - Antwoord Deel
Hello,
I replaced the back camera, but unfortunately the autofocus of the new camera does not work. All pictures are blurred. When I open the camera-app a "click-noise" can be heard. I also installed 3rd-party app, which has the option to change the focus manually. But that did not work as well. I also did a secure boot, but that also did not solve the problem. Do you have an idea, what I can do?
Thanks in advance,
Klaus
Klaus M. - Antwoord Deel
Hello,
just an update for my former question: I exchanged the camera-module again and now it is working. It seems, that the other "new" module was broken!
Cheers,
Klaus
I had a similar issue. After replacing the camera, the auto focus wouldn't work anymore. I did not test it with a manual focus app.
After some research i found out that this could have been caused by a faulty connection of the ribbon cable.
I reopened the phone, detached the ribbon cable and firmly pressed it on again. Had to repeat this twice, and after the second time the camera is doing auto focus again!
bert.wijnants - Antwoord Deel
Anyone knows where to buy the OEM Back Camera for the Nexus 5x? The connector is broken after screen replacement.
Maybe you guys can help me,
Remy B
Remy B - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 118
Altijd: 9,556
