Ga door naar hoofdinhoud
Nexus 5X Motherboard Replacement
Wat je nodig hebt
  1. Nexus 5X Motherboard Replacement, SIM Card Tray: stap 1, afbeelding 1 van 3 Nexus 5X Motherboard Replacement, SIM Card Tray: stap 1, afbeelding 2 van 3 Nexus 5X Motherboard Replacement, SIM Card Tray: stap 1, afbeelding 3 van 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Motherboard Replacement, Rear Panel: stap 2, afbeelding 1 van 3 Nexus 5X Motherboard Replacement, Rear Panel: stap 2, afbeelding 2 van 3 Nexus 5X Motherboard Replacement, Rear Panel: stap 2, afbeelding 3 van 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    A guitar pick is a good substitution for the plastic opening tool.
    Sam Sippe - Antwoord
    Here’s a photo of the location of the 18 tabs that hold the back cover in place
    Steve - Antwoord
    Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
    In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
    Hampus - Antwoord
  3. Nexus 5X Motherboard Replacement: stap 3, afbeelding 1 van 3 Nexus 5X Motherboard Replacement: stap 3, afbeelding 2 van 3 Nexus 5X Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Motherboard Replacement: stap 4, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Motherboard Replacement, Midframe: stap 5, afbeelding 1 van 1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
    Some models use a Y1 screw head.
    Kyle Wright - Antwoord
  6. Nexus 5X Motherboard Replacement: stap 6, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
    The photo seems to show that the person is opening from the top, which is the opposite of your advice. So, just want to be clear.
    Robert Konigsberg - Antwoord
    yes, open from bottom first... the pic above shows the finished product after reaching top of phone. I found it best to actually start close to the right of the usbC connector. Pushing inbetween the 2 tabs and up will release the shell.. then work clockwise.
    Chris Mayberry - Antwoord
    Chris, your advice to start to the right of the usbC connector was excellent, thank you!
    I found that my middle panel was already broken at the narrowest part just to the left of the 2-D scan code on the battery, perhaps from some ham-fisted previous repair. This seems of little consequence, there do not seem to be any electrical connections running through this part.
    Wiley Sanders - Antwoord
    After a long amount of prying, I discoved that, if used gently, a jimmy can really help get the plastic off
    Timothy Owens - Antwoord
    I could not remove the cover with the opening tool but had success with the opening picks (the triangle parts). Just slide them under the cover and gently bend and twist the pick to release the cover from the locks. By the way: it’s perfectly normal for the bottom cover part to come loose from the top cover part. It’s designed that way (they interlock).
    Marco Miltenburg - Antwoord
    Here’s a photo of the location of the 20 tabs that hold the middle assembly in place, and the pry angle needed.
    Steve - Antwoord
    This is the scariest part but it is the same process of taking a bike tire off the rim: lift up one part of the cover then put a wedge under the lifted section to hold it up then continue around the frame lifting it up and holding it up with the blue picks. You’ll find that after you life the bottom you can wriggle free the rest by hand.
    The 10 screws came out quickly using the IFIXIT.com magnetic screwdriver.
    mcguinness.david - Antwoord
  7. Nexus 5X Motherboard Replacement: stap 7, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Motherboard Replacement: stap 8, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Motherboard Replacement: stap 9, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Motherboard Replacement, Battery Disconnect: stap 10, afbeelding 1 van 2 Nexus 5X Motherboard Replacement, Battery Disconnect: stap 10, afbeelding 2 van 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Voorzichtig: stappen 11-14 komen van een handleiding die in bewerking is.
    Nexus 5X Motherboard Replacement, Motherboard Assembly: stap 11, afbeelding 1 van 1
    • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
  12. Nexus 5X Motherboard Replacement: stap 12, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Apply the flat end of a spudger to the left side of the rear facing camera and carefully lever it up. Make sure all of the adhesive underneath is loosened.
  13. Nexus 5X Motherboard Replacement: stap 13, afbeelding 1 van 2 Nexus 5X Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up the display flex connector.
  14. Nexus 5X Motherboard Replacement: stap 14, afbeelding 1 van 3 Nexus 5X Motherboard Replacement: stap 14, afbeelding 2 van 3 Nexus 5X Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Grip the lower part of the motherboard with your fingers and carefully lift it upwards.
    • There's a small plastic clip next to the rear-facing camera that holds the motherboard in place.
    • Gently pull the motherboard towards the bottom edge to free it from the plastic clip next to the rear-facing camera.
    • Carefully lift the motherboard out of the frame.
    • Be careful—the two cameras are still connected to the board.
  15. Nexus 5X Motherboard Replacement, Motherboard: stap 15, afbeelding 1 van 3 Nexus 5X Motherboard Replacement, Motherboard: stap 15, afbeelding 2 van 3 Nexus 5X Motherboard Replacement, Motherboard: stap 15, afbeelding 3 van 3
    • Proceed with the following steps if you need to transfer the front-facing and rear-facing cameras to the new motherboard.
    • Use the flat end of a spudger to pry up the rear-facing camera connector from the motherboard.
    • Carefully remove the rear facing camera.
  16. Nexus 5X Motherboard Replacement: stap 16, afbeelding 1 van 3 Nexus 5X Motherboard Replacement: stap 16, afbeelding 2 van 3 Nexus 5X Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up the front-facing camera connector from the motherboard.
    • Carefully remove the front-facing camera.
Conclusie
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where it’s necessary.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
61 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
203.353 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
40 opmerkingen
Anyone with the bootloop problem has been successful on returning the 5X to life by replacing the motherboard?
Jago MF - Antwoord
that's a stupid question. new motherboard means new operating system. maybe you should just use fastboot and flash stock firmware on your phone easy
Alek Kels -
where can I get a new motherboard at?????
Alek Kels -
in most 'google image boot' issues, it is a hardware issue, not software. besides, the phone will not allow a bootloader option.
Chris Mayberry -
yes …….and its the only way after bootloop
damneetsingh2000 -
yes…….and its the only way after bootloop
damneetsingh2000 -
same here! if anybody has luck fixing the bootloop problem by replacing the motherboard please let us know
joe - Antwoord
hello, today my phone came out of service with bootloop problem . they changed the motherboard , now everything is good
Ioan Robicek -
Has the motherboard part been removed from the "Parts" section??? Not available for purchase anymore??? That would render this guide useless
Jago MF - Antwoord
What do you mean by useless? Mobos from other suppliers require different take apart?
Emil Eriksson -
I had bootloops within the year of buying this phone but because the LG webpage RA system wasn't working I missed out by a couple days and they want to charge me $180 to repair the phone. They won't budge and I will never buy an LG again. Has anyone found replacement motherboards or fixed this phone?
Jacob Burger - Antwoord
LG offered me free repair as long as there's no physical/cosmetic/liquid damage.
Warranty expired 20 days ago btw.
Riasat Abir -
my phone was 8 months out of warranty and they just fixed as if in warranty.
Tyson Washburn -
Hi Alek Kels - 12/23/2016 - "maybe you should just use fastboot and flash stock firmware on your phone easy"
How do I do this? I'm having the bootloop problem atm.
Thanks!
Sand.
Sando Kainth - Antwoord
Don't worry about learning, because it is a hardware issue, not software. The phone will not boot proper past the fastboot.
Chris Mayberry -
It is probably a hardware problem. You can try redoing the software. It didn't work for me. You need to cook your phone. Sounds stupid right? But it works. One of the contacts for the ram or cpu is no longer good. Cooking it will melt the solder and fix it for at least a while. At least it worked for me.
I followed the instructions on a blog. Dev Alex - Oven fresh Nexus 5x.
Matt Johnson - Antwoord
This is an age old fix for crappy solder points connecting to CPUs or GPUs (most notably in HP laptops). Disassemble the phone and heat the snapdragon chip with a heat gun for 10 seconds. The chip is beneath a metal shield that pops up with a flat screwdriver. I am working to complete this now.. .will let you know how it works.
Chris Mayberry -
..alot of work for a little action. Got the phone to boot after heating the CPU for 15sec, stayed on for 4 minutes before rebooting again. ~sigh~
Chris Mayberry -
Found this forum comment re the rebooting sequence fix...
"The LG G4, V10, and the Nexus 5X are all affected by the bonded flipchip substrate breaking off of the BGA package under the CPU, which usually manifests in bootlooping or screen corruption, and eventually a complete brick. It’s not solder related; the only way to fix it is by completely replacing the CPU package with one that isn’t defective. – FrankTheCat"
Chris Mayberry -
Flashing stock image doesn't work for everybody with the bootloop issue. In my​ case, I can reboot into bootloader and have already installed 3 different stock images successfully and am STILL getting stuck on bootloop. From what I've researched it does seem to be a hardware issue.
Thunor Odinson - Antwoord
Hey my phone is continously restarting and a
Stucking at bootloop and sometimes it starts but gets restart
pranav g - Antwoord
Trying the oven bake fix now, just started bootlooping. I'm not counting on it working for long, already ordered a pixel. Thanks for the great guide!
Stephen Moist - Antwoord
Hi, I know is very complicated but, is it possible to get the data from old motherboard memory storage? any type of hack or something...
Manuel Ramirez - Antwoord
put it in the freezer for about 20 mins
Tyson Washburn -
Where can i buy a new motherboard
Jochen - Antwoord
How much it cost to replace motherboard of nexus 5x if it is not in warranty? and what is warranty period for newly replaced part?
Manisha Kulthe - Antwoord
today i have gone to lg service center and they were askin for 12k rs. for mother board replacement but after bargaining they agreed at 6
damneetsingh2000 -
damneetsingh 2000 where is that service centre
uday -
I need a mother boad nexus 5x. From where can i get it
Nityananda Mondal - Antwoord
Does anyone knows where I can buy the motherboard for my Nexus 5X.
Candy Beato - Antwoord
Last day I’m using Facebook APPs suddenly phone are freeze with doesn’t work. When are phone restart display Appear in GOOGLE Logo then phone is OFF, that’s means bootloop problem. Now, I need a mother board LG Nexus 5X. Buy with from where can i get it.
Najmul - Antwoord
STEP 4 photo, second window on the bottom of the phone from right, (between two red circles) there is little opening (there are few on phone) and there a little device looking as a spring or something. By replacing battery this thing felt off.
I was very careful not to damage anything, but still... so careful… Device looks like to be clued there, I would love to know what is it for, can someone help, please? it looks like a senzor or something
Zdenek Otcenasek - Antwoord
do a websearch on repairing the nexus 5x bootloop… in the oven! I removed the shield from the side facing the screen, put flux all over especially the samsung chip, and baked it at 400F for 6.5 minutes - samsung chip side up, now the phone is working properly again, enough to backup all files. Eventually replacing samsung chip with new one will be necessary to get good solder contacts.
Shawn Foster - Antwoord
Bootloop problem sorted!! Thanks OP
Robert Huddleston - Antwoord
Dec 14, 2017:
Encompass Supply Chain Solutions is parts supplier for LG for the US East Coast time zone area.
Went to their parts web page for the Nexus 5x (LGH790) - https://lg.encompass.com/model/LGELGH790
Motherboard (refurbished) costs $270 and ships in 60 days.
mws3d - Antwoord
Do you know if is it possible to change 16 Gb main board by 32 Gb mainboard?
Aymeric Golliaud - Antwoord
hello damneetsingh 2000 ,where is that lg service centre.I also want to change my other board
uday - Antwoord
i need to purchase the motherboard international
Jackson Makinda - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 49
Altijd: 62,822
