Inleiding
Use this guide to replace a malfunctioning battery. This replacement guide requires a Soldering Iron, it would be very helpful to heat the iron up before starting this guide, this process can take 3-4 minutes. You should refer to iFixit's soldering guide to help with the desoldering/soldering process.
Wat je nodig hebt
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
Remove yellow tape with a black edge that covers the red, white and black wires.
4 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Excellent guide, easy to follow, very concise, very good photographs. Thank you
Donde puedo encontrar una batería
