Ga door naar hoofdinhoud
NeuTab Air7 Battery Replacement
Wat je nodig hebt
    1. NeuTab Air7 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 NeuTab Air7 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 NeuTab Air7 Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Ensure your device is powered off before you begin.
      • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. NeuTab Air7 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 NeuTab Air7 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
      • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
      • For a guide on how to solder, click here.
      • Remove any adhesive tape that is holding the wires protruding from the battery down.
      • De-solder the red and black wire ends that connect the battery to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. NeuTab Air7 Battery Replacement: stap 3, afbeelding 1 van 2 NeuTab Air7 Battery Replacement: stap 3, afbeelding 2 van 2
      • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
      • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jason Soares
532 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 435
