Inleiding
The Motorola Moto G6, like most phones, houses a motherboard that connects all of the components of the device and controls its subsystems. In order to remove many of the Moto G6’s commonly-replaced components, the motherboard must be removed first. Use this guide to successfully take the motherboard out of your Moto G6.
No repair experience is required. However, this replacement will require tools to remove the needed components of the device. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below.
Wat je nodig hebt
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
Use the opening tool to disconnect the press-fit connection on the top left of the motherboard, similar to the previous step.
Use either your fingernail or tweezers to pull the orange boxed connector out. Unlike the other connections, this one is pulled down and not up from the device.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Where can I purchase a Moto G6 logic board refurb or new, online?
