Inleiding
Use this guide to replace the daughterboard in the Motorola Moto C.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Wat je nodig hebt
Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a finger or spudger to lever the battery out of its recess and remove it.
Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
Apply new adhesive where it’s necessary.
