Ga door naar hoofdinhoud
Microsoft Surface Pro 7 Screen Adhesive Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: stap 1, afbeelding 1 van 3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: stap 1, afbeelding 2 van 3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: stap 1, afbeelding 3 van 3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: stap 2, afbeelding 1 van 2 Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: stap 2, afbeelding 2 van 2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: stap 3, afbeelding 1 van 1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sam Omiotek
83.789 Reputatie
290 handleidingen geschreven
2 opmerkingen
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - Antwoord
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 108
Altijd: 5,870
