Ga door naar hoofdinhoud
Microsoft Surface Laptop 3 13.5" Feet Replacement
Wat je nodig hebt
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: stap 1, afbeelding 1 van 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: stap 1, afbeelding 2 van 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: stap 2, afbeelding 1 van 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: stap 2, afbeelding 2 van 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: stap 3, afbeelding 1 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: stap 3, afbeelding 2 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: stap 3, afbeelding 3 van 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: stap 4, afbeelding 1 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: stap 4, afbeelding 2 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: stap 4, afbeelding 3 van 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: stap 5, afbeelding 1 van 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: stap 5, afbeelding 2 van 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: stap 6, afbeelding 1 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: stap 6, afbeelding 2 van 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: stap 6, afbeelding 3 van 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Carsten Frauenheim
114.572 Reputatie
339 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.295 handleidingen geschreven
Één opmerking
Nice, that good for me, first time :D
TrungLun0112 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 175
Altijd: 5,768
