Ga door naar hoofdinhoud
Microsoft Surface Book Keyboard USB Port Replacement
Wat je nodig hebt
  1. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: stap 1, afbeelding 1 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: stap 1, afbeelding 2 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: stap 1, afbeelding 3 van 3
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
    Vraag FixBot
    Voeg opmerking toe
  2. Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: stap 2, afbeelding 1 van 2 Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: stap 2, afbeelding 2 van 2
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
    Vraag FixBot
    Voeg opmerking toe
  3. Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: stap 3, afbeelding 1 van 2 Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: stap 3, afbeelding 2 van 2
    • Straighten out one section of a paper clip.
    Vraag FixBot
    Voeg opmerking toe
  4. Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: stap 4, afbeelding 1 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: stap 4, afbeelding 2 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: stap 4, afbeelding 3 van 3
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
    Vraag FixBot
    Voeg opmerking toe
  5. Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: stap 5, afbeelding 1 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: stap 5, afbeelding 2 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: stap 5, afbeelding 3 van 3
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
    Vraag FixBot
    Voeg opmerking toe
  6. Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: stap 6, afbeelding 1 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: stap 6, afbeelding 2 van 3 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: stap 6, afbeelding 3 van 3
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
    Vraag FixBot
    Voeg opmerking toe
  7. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display: stap 7, afbeelding 1 van 1
    • Completely power down your Surface Book before opening it up for any repairs.
    Vraag FixBot
    Voeg opmerking toe
  8. Microsoft Surface Book Keyboard USB Port Replacement, Back Panel: stap 8, afbeelding 1 van 1
    • Flip the keyboard over so you can see the back panel.
    Vraag FixBot
    Voeg opmerking toe
  9. Microsoft Surface Book Keyboard USB Port Replacement: stap 9, afbeelding 1 van 2 Microsoft Surface Book Keyboard USB Port Replacement: stap 9, afbeelding 2 van 2
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
    Vraag FixBot
    Voeg opmerking toe
  10. Microsoft Surface Book Keyboard USB Port Replacement: stap 10, afbeelding 1 van 1
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
    Vraag FixBot
    Voeg opmerking toe
  11. Microsoft Surface Book Keyboard USB Port Replacement, USB Port: stap 11, afbeelding 1 van 1
    • Orient your keyboard with the internals facing up and the USB Port on the right.
    Vraag FixBot
    Voeg opmerking toe
  12. Microsoft Surface Book Keyboard USB Port Replacement: stap 12, afbeelding 1 van 1
    • Use a plastic opening tool and remove the tab from the USB board
    Vraag FixBot
    Voeg opmerking toe
  13. Microsoft Surface Book Keyboard USB Port Replacement: stap 13, afbeelding 1 van 2 Microsoft Surface Book Keyboard USB Port Replacement: stap 13, afbeelding 2 van 2
    • Lift up the black and gold wires and find the screw hidden there.
    • Use the T3 Torx Screwdriver and remove the four mm screw.
    Vraag FixBot
    Voeg opmerking toe
  14. Microsoft Surface Book Keyboard USB Port Replacement: stap 14, afbeelding 1 van 1
    • Use the T3 Torx Screwdriver to remove the remaining three 4 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  15. Microsoft Surface Book Keyboard USB Port Replacement: stap 15, afbeelding 1 van 2 Microsoft Surface Book Keyboard USB Port Replacement: stap 15, afbeelding 2 van 2
    • Wiggle the USB Port board away from the keyboard.
    • This may require some force.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Natalie Weisenburger
593 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-3, Livingston Fall 2016 Lid van Cal Poly, Team 20-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G3
4 Leden
12 handleidingen geschreven
5Gids Commentaar
But how do you remove and re-attach the ribbon cables without damaging them? Seems like an important detail that is left out.
Brandon M - Antwoord Deel
How do you re-glue the bottom cover back on?
Mike Guarino - Antwoord Deel
Where do you get the replacement USB board? Is there’s a part number for it that I can look up?
wheetcracker - Antwoord Deel
Can the same be done for the type c port
Pavan Kumar - Antwoord Deel
There are quite a few questions raised Tunnel Rush. Maybe I missed a few details in the manual.
stevens gomez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 64
Altijd: 7,109
