Ga door naar hoofdinhoud
Merch Source Projector Entertainment II Cooling Fan Replacement
Wat je nodig hebt
  1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    Vraag FixBot
    Voeg opmerking toe
  2. Merch Source Projector Entertainment II Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
    Vraag FixBot
    Voeg opmerking toe
  3. Merch Source Projector Entertainment II Cooling Fan Replacement: stap 3, afbeelding 1 van 2 Merch Source Projector Entertainment II Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
    Vraag FixBot
    Voeg opmerking toe
  4. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: stap 4, afbeelding 1 van 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: stap 4, afbeelding 2 van 2
    • Locate the 80 mm fan and slide upward straight out of the housing.
    Vraag FixBot
    Voeg opmerking toe
  5. Merch Source Projector Entertainment II Cooling Fan Replacement: stap 5, afbeelding 1 van 2 Merch Source Projector Entertainment II Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Unsolder the red and black connections off of the motherboard.
    • If there are zip ties around the cables, they will need to be cut to remove the fan.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections will get very hot. Never touch the iron with your hand.
    • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
    • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephanie
282 Reputatie
3 handleidingen geschreven
Cal Poly, Team 18-3, Maness Winter 2015 Lid van Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 2,804
