Ga door naar hoofdinhoud
Marshall Stanmore II Tweeter Assembly Replacement
Wat je nodig hebt
    1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: stap 1, afbeelding 1 van 2 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: stap 1, afbeelding 2 van 2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      Vraag FixBot
      Voeg opmerking toe
    2. Marshall Stanmore II Tweeter Assembly Replacement: stap 2, afbeelding 1 van 2 Marshall Stanmore II Tweeter Assembly Replacement: stap 2, afbeelding 2 van 2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. Marshall Stanmore II Tweeter Assembly Replacement: stap 3, afbeelding 1 van 2 Marshall Stanmore II Tweeter Assembly Replacement: stap 3, afbeelding 2 van 2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      Vraag FixBot
      Voeg opmerking toe
    1. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: stap 4, afbeelding 1 van 2 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: stap 4, afbeelding 2 van 2
      • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
      Vraag FixBot
      Voeg opmerking toe
    2. Marshall Stanmore II Tweeter Assembly Replacement: stap 5, afbeelding 1 van 3 Marshall Stanmore II Tweeter Assembly Replacement: stap 5, afbeelding 2 van 3 Marshall Stanmore II Tweeter Assembly Replacement: stap 5, afbeelding 3 van 3
      • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
      • Repeat for the second connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Marshall Stanmore II Tweeter Assembly Replacement: stap 6, afbeelding 1 van 2 Marshall Stanmore II Tweeter Assembly Replacement: stap 6, afbeelding 2 van 2
      • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
      • Lift the tweeter assembly from its housing.
      Vraag FixBot
      Voeg opmerking toe
    4. Marshall Stanmore II Tweeter Assembly Replacement: stap 7, afbeelding 1 van 1
      • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
      • Repeat steps 4-6 to remove the second tweeter if necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
1Gids Commentaar
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 824
