Ga door naar hoofdinhoud
Marshall Stanmore II Subwoofer Assembly Replacement
Wat je nodig hebt
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: stap 1, afbeelding 1 van 2 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: stap 1, afbeelding 2 van 2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      Vraag FixBot
      Voeg opmerking toe
    2. Marshall Stanmore II Subwoofer Assembly Replacement: stap 2, afbeelding 1 van 2 Marshall Stanmore II Subwoofer Assembly Replacement: stap 2, afbeelding 2 van 2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. Marshall Stanmore II Subwoofer Assembly Replacement: stap 3, afbeelding 1 van 2 Marshall Stanmore II Subwoofer Assembly Replacement: stap 3, afbeelding 2 van 2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      Vraag FixBot
      Voeg opmerking toe
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: stap 4, afbeelding 1 van 3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: stap 4, afbeelding 2 van 3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: stap 4, afbeelding 3 van 3
      • Pull back the clear sheaths on the end of each wire to expose the terminals.
      • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
      • Failure to press the latch while pulling could damage the subwoofer and/or wires.
      Vraag FixBot
      Voeg opmerking toe
    2. Marshall Stanmore II Subwoofer Assembly Replacement: stap 5, afbeelding 1 van 1
      • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
      • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Marshall Stanmore II Subwoofer Assembly Replacement: stap 6, afbeelding 1 van 1
      • Carefully lift the subwoofer assembly away from the housing.
      Vraag FixBot
      Voeg opmerking toe
    4. Marshall Stanmore II Subwoofer Assembly Replacement: stap 7, afbeelding 1 van 1
      • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 69
Altijd: 1,370
