Ga door naar hoofdinhoud
Marshall Stanmore II Power Switch Replacement
Wat je nodig hebt
  1. Marshall Stanmore II Power Switch Replacement, Rear Panel: stap 1, afbeelding 1 van 2 Marshall Stanmore II Power Switch Replacement, Rear Panel: stap 1, afbeelding 2 van 2
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Vraag FixBot
    Voeg opmerking toe
  2. Marshall Stanmore II Power Switch Replacement: stap 2, afbeelding 1 van 2 Marshall Stanmore II Power Switch Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Vraag FixBot
    Voeg opmerking toe
  3. Marshall Stanmore II Power Switch Replacement: stap 3, afbeelding 1 van 2 Marshall Stanmore II Power Switch Replacement: stap 3, afbeelding 2 van 2
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Vraag FixBot
    Voeg opmerking toe
  4. Marshall Stanmore II Power Switch Replacement, Power Switch: stap 4, afbeelding 1 van 3 Marshall Stanmore II Power Switch Replacement, Power Switch: stap 4, afbeelding 2 van 3 Marshall Stanmore II Power Switch Replacement, Power Switch: stap 4, afbeelding 3 van 3
    • Locate the Power Switch PCB on the left-hand side above the subwoofer.
    • Use a Phillips #2 screwdriver to remove the two 10 mm screws that secure the PCB.
    • Because the space inside is somewhat cramped, consider using the iFixit 150 mm Flex Extension included in the iFixit Pro Tech Toolkit.
    Vraag FixBot
    Voeg opmerking toe
  5. Marshall Stanmore II Power Switch Replacement: stap 5, afbeelding 1 van 2 Marshall Stanmore II Power Switch Replacement: stap 5, afbeelding 2 van 2
    • Locate the PCB's black wire connector and gently disconnect it.
    • Do not pull on the wires.
    Vraag FixBot
    Voeg opmerking toe
  6. Marshall Stanmore II Power Switch Replacement: stap 6, afbeelding 1 van 3 Marshall Stanmore II Power Switch Replacement: stap 6, afbeelding 2 van 3 Marshall Stanmore II Power Switch Replacement: stap 6, afbeelding 3 van 3
    • Pull the PCB out of the mount.
    • Take care not to damage the rubber seal surrounding the switch base as depicted in picture two.
    • Rocking the PCB back and forth while pulling may help remove the module.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Hellooooo very good but were did you fint the eplace the power switch ?
Fred - Antwoord Deel
Where can buy on /off switch ?
Choi Kee - Antwoord Deel
On/off switch bar is broken
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 109
Altijd: 2,882
