Ga door naar hoofdinhoud
MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Antwoord
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Antwoord
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Antwoord
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Antwoord
    This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
    Evan Shulman -
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
    Hi peeps,
    I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
    However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
    Any advice /close up photos is welcome here.
    dom
    colonel mustard - Antwoord
    Tip: Use post-it notes to keep track of screws
    1. Pack of post it notes
    2. Stick screws to the sticky part of the post it note
    3. Write on the post it note which step and what kind of screw it is
    ibash - Antwoord
    Hi, in order to drain the battery I am running:
    yes > /dev/null
    in 4 terminals, so the CPU maxes out at almost 99%.
    I hope this speeds up the battery draining process.
    And the backlight is at maximum brightness :-)
    You can see the cpu load in Activity Monitor.
    Its draining at 20% per 15 minutes.
    Any concerns about draining the battery in this way?
    Andre van der Ham - Antwoord
    Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
    Chat Dawgie - Antwoord
    Without rehashing what others have said, I would highly recommend reading through the steps *and* the comments for each before tackling your replacement for tips. Highlights for me were: only disconnecting what actually needed to be disconnected, rotating the spudger to release the track pad cable, a hair dryer worked perfectly fine, and the pencil outline of the battery before you remove. You got this!
    N DesRochers - Antwoord
    Installation of replacement AirPort card was easier than I had expected thanks to this guide. Thank you.
    chaslaw - Antwoord
    I use replaced SSD and it was super easy and working great. I can finally upgrade Mac OS with plenty of room to spare and no more low memory alerts. Well worth investment and didn’t have to buy new laptop
    Pete James - Antwoord
    It's interesting that this tutorial is rated Moderate even though you need to remove the battery. The battery removal tutorial which is basically the same but with fewer steps is rated Difficult.
    Marv Ruona - Antwoord
    when i pulled the screws out i arranged them in the same way they were in. the top 2 middle screws appeared to be shorter than the rest. in order to keep them in place i got a square of packing tape sticky side up, taped both sides down with 2 other pieces of tape. and then put the screws head down in the order i pulled them.
    Jason Wade - Antwoord
    Excellent instructions although checking battery and speakers aligned before fixing batteries into place is essential. MacBook good as new!
    John Foreman - Antwoord
    I find it helpful to spread a soft, slightly fuzzy cloth (like flannel) over my workspace before doing something with small parts. It keeps screws and things from rolling or bouncing away. A towel might be too plush, though, as a screw might get lost in it.
    Richard KeslerWest - Antwoord
    I cannot get the two screws (that are different than the other ones) out and now they’re stripped. Any idea what to do without using a drill?
    Honeybee94 - Antwoord
    DO NOT REMOVE SPEAKER CABLES!! The connectors are fragile. Just remove speakers and bend attached cable away from battery. Same for trackpad cable connector at front side. This cable crosses the middle of the battery. Just remove the one connector on the back side - leave front side connector attached and fold cable toward front of computer out of way of battery.
    Paul Lebow - Antwoord
  2. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Antwoord
    To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
    Peter Stoll - Antwoord
    If your old battery has swollen, the lower case may “pop” open. Don’t lose your screws!
    Maxine Loveman - Antwoord
  3. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 3, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 3, afbeelding 2 van 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Antwoord
    I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
    Evan Shulman - Antwoord
    If you’re doing an iFixIt battery replacement, the replacement battery has two rubber nubs which are right where the clips are that receive these studs. Folks have been saying it’s hard to get the studs to clip back in after replacement, and I had the same issue. I trimmed the top of these rubber nubs, which are a bit bigger than those on the original battery, with some side cutters. That made the fit much better.
    Rob Gorbet - Antwoord
  4. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Battery Connector: stap 4, afbeelding 1 van 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
    A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
    Daniel Brehm - Antwoord
    I have done tons of these battery replacements.
    You don’t need to do anything on the list after you disconnect the battery, apart from carefully moving the speakers out of the way, and then prise up the battery modules. I just very carefully, and with little even motions, use a large slot screwdriver. Being careful to keep it flat, to not puncture the battery.
    Easy peasy. I have never had an issue after dozens of the tasks…
    davelarose - Antwoord
    Dear Sir,
    as you seem to be very much experienced with battery replacements you might perhaps give me a hint why after having removed the battery pack successfilly, the keyboard doesn't work anymore after booting the system. The Touchpad works, the keyboard backlight works but typing does not function at all.
    I only disconnected the battery connector and touched nothing else. I am quite desperate …
    Gerd Uyan -
    I agree with Dave la Rose, provided you use heat rather than solvent to remove the old battery (or possibly floss, haven’t done that). Please see my comment further down this thread on how to use an iOpener for correctly heating the glue joint
    I. Margaronis - Antwoord
    After removing battery contact board plastic. My screwdriver accidentally fell and touched the battery board. And it short circuited. Now my battery doesn't charge. My laptop doesn't work without charger now. shuts after a few minutes of use. Can i fix it without sending it for repairs?
    Phillip Ngwenya - Antwoord
    Is replacing the battery necessary?
    Ralph Louis - Antwoord
    How do we know if it's necessary to replace the plastic cover adhered to the battery contact board?
    What are the factors that would require that?
    Lux - Antwoord
  5. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 5, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 5, afbeelding 2 van 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Antwoord
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Antwoord
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Antwoord
    Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
    Jaden Salama - Antwoord
    The connector is no more than 1mm thick… the socket is 3-to-4mm deep so make sure you’re trying to remove the connector itself, and not pulling at the socket.
    Richie Egg - Antwoord
    Thank you Richie I was trying to lift the socket.
    be careful the little square block is actually made of 2 parts and you only have to lift the upper part as Richie said
    ilyes - Antwoord
    You can do it from the side like the picture, but i would recommend twisting almost like a screw driver once you have leverage under the overhanging part of the left side like in the picture. Twist the tool so that it starts to put pressure on the top, until you’ll hear it click out. You can be somewhat forceful but it shouldn’t require a lot of strength. Guiding the tool with one hand and twisting with the other is a good way to attempt this.
    Colin Nowers - Antwoord
    After I put the battery back I found out at this step that the new battery connector was off by 2 mm (because I installed my battery slightly off). Since the connector is rigid, I removed it’s plastic cover (just like we all did in Step 4) to free the cable, which allowed me to bent it enough to properly plug the connector.
    Marc - Antwoord
    Simple question: why we need to do this, I mean, disconnect battery from main board?
    Bin Zhu - Antwoord
    Well, I’m reading this step in the battery replacement repair guide, so it’s pretty critical to disconnect the battery from the main board. I’m guessing these steps are reused in other guides where disconnecting the battery might not be such an obvious need.
    surf -
    Also wondering the same. I came here from a link to replace the fan. Is it necessary to disconnect the battery inorder to replace the fan?
    Chris Andrews -
    The connector wires from the battery to the connector are long
    You'll have to bend them downward and into the small cove that exists so the connector can fit in place.
    So use the a plastic card or flat end of the spudger to bend them downward and folded a bit back so the connector will fit in place.
    Use your old battery as a guide for how they should be bent.
    RON BUENO - Antwoord
    Hi All ,
    I followed the instructions step by step and changed the board successfully and reconnected everything back. When I powered it back on I can see it is charging again however it just displays a black screen and no display. Keyboard light comes on as well and the apple logo light on the back lid also turns on. Not sure what is wrong ? It has been charging for more than 15 minutes and still no joy. Anyone able to help solve or identify the issue .
    Thanks
    Kaleem - Antwoord
    The connector cover is slightly wider and longer than the socket (<1mm) so there is a small "lip" around the top that can be used to lift it.
    If your are not familiar with those repairs, and as with most of those connections, I recommend to take the time to observe your computer and the pictures from the tutorial, reading instructions and comments before starting each step. This battery connector needs both a bit of force and of precision. For a battery repair the connection of the new battery is a bit more tricky, you need to have your battery in the right position and to force it a bit the connector
    David Obis - Antwoord
    Hi, I only want to remove/examine/possibly replace the left speaker as it's crackling..........I don't think I need to remove the battery connector to the logic board?
    Mickeytix - Antwoord
  6. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 6, afbeelding 1 van 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Antwoord
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Antwoord
    @sebasgaes, shoot, I'm only part way through the process, but I skipped this step thinking it wasn't necessary. I'm only through step 12 right now, but is there a fix if my machine doesn't recognize the wifi hardware after I've put it all back together? I don't see reference to the "I/O board cable" anywhere else in the instructions, so I'm confused about your mention of that...
    jiclark - Antwoord
    UPDATE: I completed the job, rebooted, and all is well, wifi and all. Thanks anyway; gotta love iFixIt!!
    jiclark -
  7. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Heat Sink: stap 7, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Heat Sink: stap 7, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Heat Sink: stap 7, afbeelding 3 van 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
    have lost the rubber fann bumper, what part do you have to buy to get this rubber? thank you
    Walid Shraim - Antwoord
    I changed out the noisy fan around 4-5 months ago. And lately it was back and I was super irritated about the poor quality of the replacement fan. Opening up the case and blowing on the ventilator some compressed air there was no noise whatsoever. I have this feeling that my “noisi fan” was actually the loose end of this rubber cover/bumper which could vibrate in the air flow channel. So verify that you insert rubber cover clips back to its slots on under the edge of the sink.
    Albert Stein - Antwoord
    Use a flashlight and magnifying glass to see how the bottom of the bumper that wraps around the heatsink sits into the fan duct before you remove it. If it is not seated properly it can make noise. You’re welcome.
    Ron LaPedis - Antwoord
  8. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
    Ok, might be a dumb question, but where can I get the foam stickers, and are they absolutely necessary after reassembling the heat sink?
    akdarstudios - Antwoord
    I re-used the ones that I pulled off, and my guess is that they aren’t really necessary since they seem to just fit between the Torx screws and the bottom cover. I really doubt they are part of the heat removal system but are there to prevent vibration.
    When I removed the pads, they separated from the double face tape adhering them to the screws. The tape stuck to the screws. I lifted the tape off with a utility knife and saved it. On reassembly, the tape would stick to the screws, but would not hold the pads. Still worthwhile putting the tape on the screws because it keeps adhesive from clogging the head of the screw. I cleaned the pads well (IPA or denatured alcohol will work). To get them to stick I put a minuscule dab on the screw and on the bottom of the pad.
    fba - Antwoord
  9. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 9, afbeelding 1 van 1
    • Remove the following screws securing the heat sink to the logic board:
    • One 2.7 mm T5 screw (silver)
    • Four T5 screws (black)
    Please be very very careful when reassembling. The four black screws seem to be poor quality and the top snapped off two of them when trying to tighten them. Does anyone know the size of these or compatibility from other models as finding a replacement for them is proving to be almost impossible without shipping them in for a ridiculous price…
    Sophia Grace - Antwoord
    The single screw on the left hand side on the image above, what type of screw is it? The one on my Macbook is a phillips head one. And for some reason, I couldn’t put it back. Any advise?
    Mahmood Chowdhury - Antwoord
    These should all be T5 Torx screws. There could be variations in the construction of the laptop compared to this guide, but I’d check out our ID Your MacBook tool to be sure you’re following the correct guide! If you are following the correct guide, be sure all the elements under the screw are properly seated, if they’re not well aligned the screw may not get a good anchor. Best of luck!
    Sam Goldheart -
    I can confirm that on my 2015 13” Macbook Pro, the single screw on the left hand side is a #000 phillips screw.
    Stephen Martin - Antwoord
    Mine is also a philips head
    Justin Parry - Antwoord
    They are Torx T5 on my MacBook Pro (Retina, 13-inch, Early 2015)
    I’m doing 2 early 2015 13” macbook pro’s right now simultaneously and both have same size torx for all 5 screws. Upgrading logic board in one and putting its old logic board in dead mac.
    BTW, I’m a double EE, been doing this a long time and wanted to mention that i use only high quality German made tools for my torx and other drivers. I have found repeatedly, that the cheap tools that are given away in kits, wear out fast, sometimes after one use and lead to issues with fasteners. My drivers are made by WIHA. They are expensive but well worth it if you plan on doing this more than once or even once!
    Ross Elkins - Antwoord
    yes, Phillips head screw on 13-inch early 2015 retina for my unit 2.7 ghz, 8gb ram
    robert - Antwoord
    For those of you that do have the Phillips head for the single screw on the left-hand side, do you have a driver suggestion that worked well for you, without stripping the head? I have tried the 000 bit and one of the 000 drivers from ifixit but those are beginning to strip the head. I need a driver that has deep drive but I’m unsure as to which brand I should buy. I’ll spend the money for the right driver. Thanks!
    Ray Grogan - Antwoord
    You can't go wrong with WIHA.
    maccentric -
    Dumb question - if my replacement logic board comes with a new heat sink attached, can I ignore these steps (other than removing the red-circled screw)? Hoping so since this part seems like a PITA.
    Steve Kroodsma - Antwoord
    I too have a Phillips head for that one screw (early 2015 13” retina MBP, technically an Apple refurb). The bit I used is labelled J000 from my precision toolkit. Be careful since it so small, but i had no issues with tearing up the screw head.
    Edward Wilcox - Antwoord
  10. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 10, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 10, afbeelding 2 van 2
    the use of a CLEAN (with isopropyl alcohol) credit card was very helpful when reapplying the thermal paste, be sure to have this “tool” on hand when reassembling.
    Colleen V - Antwoord
    We need a picture of reinstallation of the 2.7mm T5 screw on the left side of the thermal bar on the head sink. That screw goes into the stud that was previously installed. It is the only place in the computer that uses a combination post. In my machine, that screw was not silver. I don't know if that was standard or not.
    James Mitchell - Antwoord
  11. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Fan: stap 11, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Fan: stap 11, afbeelding 2 van 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    I found this to be the most difficult step. There is a need to get positioned so that you have the leverage to push hard enough at exactly the point shown in the photo without risking slipping and perhaps damaging the CPU nearby
    Tony M - Antwoord
    Very helpful tip from Tony.
    Thomas Sturgill - Antwoord
    I used two tools simultaneously. A spudger and a pic like spudger to walk it out.
    lucas - Antwoord
    Man muss den Stecker aus der Steckverbindung herausschieben, und nicht darauf drücken . In der englischsprachigen Anleitung steht auch push und nicht etwa press…
    Holger - Antwoord
    There are 2 black tabs either side - force them towards the back of the back of computer. It seemed to pop out super easily just doing it gently.
    Josh - Antwoord
    This step is very difficult. With care it could be omitted. After detach the cable from the glue on the back cover of fan, there is enough clearance to take the fan assembly out with a little pivoting, just be careful and don’t put too much stress on the table where it make a 90 downward turn to the connector. Reinstalling is just reverse and doable as well.
    Xiaokun Xu - Antwoord
    After readying all, trying Josh’s tip with no joy, I found that two nice sized fingernails made this easy x 2! Just push on each little indent simultaneously.
    Thanks Ross! This was my 2nd time every opening a laptop and using two finger nails to push on the little indents worked amazing!
    Carolyn Wang - Antwoord
    I pulled the cable directly and it got off easily.
    When assembling it,just used two fingernail on two sides of the plug and pushing it back。
    After all these,checked iSight working well。
    Junjie2021 - Antwoord
    Is there any hope for me? I did this step wrong and the connector came off the motherboard. Can that piece be glued back in place?
    Leslie Nuss - Antwoord
    I did this with the help of some sturdy toothpicks :)
    KamFix - Antwoord
  12. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 12, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 12, afbeelding 2 van 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 13, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 13, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 13, afbeelding 3 van 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
    my cable was glued, had to be pryed up first.
    maccentric - Antwoord
    I found it a bit difficult to know exactly when the new one is back in position.
    steffen - Antwoord
    Take a close look at the spacing in the 3 photos. You essentially just flip the tab 90 degrees to stay vertical, then you pull the cable carefully out. When putting the new one in, no need to press hard. Just a little bit so you have that 2-3 mm spacing and then flip the tab back down.
    Daniel - Antwoord
    During reassembly, before screwing down the fan, it is best to reinsert and lock down this cable.
    LSD - Antwoord
  14. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 14, afbeelding 1 van 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
    When reinstalling, do the screw closest to the front of the computer first.
    Steve Wechsler - Antwoord
    I second this advice as I screwed the fan in first and then tried to plug the cable in and the angle required to get it in put too much tension and the plug separated from the cable (very fragile). So now I had to order a new one.
    Joe Healy - Antwoord
  15. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 15, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 15, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 15, afbeelding 3 van 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
    Um, this guide should include steps for applying thermal paste, including instructions to clean the mating surfaces, and pictures showing how much thermal paste to use.
    TheIronGiant - Antwoord
    Hi @theirongiant, there are generic thermal paste application instructions linked in the introduction “Don't forget to follow our thermal paste application guide before you reinstall your heat sink.”
    Sam Goldheart -
    Make sure to put the end furthest away from the hinge under the ribbon cable first.
    Then place the hinge side. The screw furthest away from the hinge is partially obscured by the ribbon cable.
    If not placed correctly, ribbon cable damage may result.
    toodarkpark - Antwoord
    Thanks to toodarkpark, it’s the priority to connect the cable of Fan before place it on position completely.
    If reverse the step, it will become ALMOST IMPOSSIBLE to insert the cable.
  16. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Logic Board Assembly: stap 16, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Logic Board Assembly: stap 16, afbeelding 2 van 2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  17. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 17, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 17, afbeelding 2 van 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  18. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 18, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 18, afbeelding 2 van 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  19. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 19, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 19, afbeelding 2 van 2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 20, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 20, afbeelding 2 van 2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  21. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 21, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 21, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 21, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  22. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 22, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 22, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 22, afbeelding 3 van 3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    In my 2015 retina MacBook Pro 13”: I saw as shown the piece of black plastic tape. One peels this off as shown, using the same tweezers shown, or something else. The tweezers shown work well to lift the stainless steel clip, again as shown. But I add here that the points of the ribbon cable to grab and pull horizontally back are not optimal, as shown. You do not have to grab the ribbon. There are two points where the wire clip attaches to the connector that work well as places to grab with the tweezers shown. Hope this is clear
  23. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 23, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 23, afbeelding 2 van 2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  24. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 24, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 24, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 24, afbeelding 3 van 3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
    I wasn’t careful enough or something, the socket came straight off, ouch. I don’t even see how it was connected originally. Not soldered or anything, will try to solder myself but it looks very thin. Be careful!
    Ray Dai - Antwoord
  25. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 25, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 25, afbeelding 2 van 2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  26. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 26, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 26, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 26, afbeelding 3 van 3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
    This tiny connector was difficult for me, and I hope I have not damaged it. Same design as some connectors already removed. A tiny, plastic front latch is lifted up, causing release. You grab the ribbon cable and pull it back horizontally, and to my surprise, this is end is just one tiny flat metal end, no multiple wire connectors that mate on the male end of the ribbon cable.
  27. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 27, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 27, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 27, afbeelding 3 van 3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
    Also very difficult, because there is so little room to wriggle the ribbon cable, horizontally and backward. The photos do not offer a solution. The points I used are white (at least not black) points on the both, outer edges, and I was able to push there with the tip of the spudger.
  28. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 28, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 28, afbeelding 2 van 2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  29. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 29, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 29, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 29, afbeelding 3 van 3
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
    • Fold the cable out back over the battery to clear the way for the logic board.
  30. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 30, afbeelding 1 van 1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    Il y en a une plus longue que les autres.
    Easy Repair - Antwoord
  31. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 31, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 31, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 31, afbeelding 3 van 3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    It won't come off; help!
    Zelma Garza - Antwoord
    It seems to be stuck on the thunderbolt ports for me won’t come out
    Brendan O'Rourk - Antwoord
    i found that it was difficult to get the processor back inside correctly during reassembly. it might take a few tries, as there are small “bracket” type pieces on the underside of the i/o ports that may bend out of shape. use caution, be exceedingly gentle and patient, but don’t give up!
  32. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement, Dual Microphone Assembly: stap 32, afbeelding 1 van 1
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  33. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 33, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 33, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 33, afbeelding 3 van 3
    • Lift the corner of the left speaker up and slide it toward the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  34. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 34, afbeelding 1 van 1
    • Remove the single 3.7 mm T5 Torx screw securing the case-edge of the battery contact board.
  35. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 35, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 35, afbeelding 2 van 2
    • Insert the tip of a spudger under the battery-side portion of the rubber microphone cable cover to detach the adhesive there.
  36. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 36, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 36, afbeelding 2 van 2
    • Use the flat end of a spudger to wedge the battery contact board up slightly to allow room to extract the dual microphone assembly.
  37. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 37, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 37, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 37, afbeelding 3 van 3
    Koop
    • Remove the rubber microphone cover with a set of tweezers
    • Be careful not to snag the cover on the screw post in the case or on the battery contact board.
  38. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 38, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 38, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 38, afbeelding 3 van 3
    • Insert the tip of a spudger underneath the connector end of the microphone ribbon cable and slide it toward the screw post to free that half from the upper case.
    • If the microphone is very resistant to prying, try heating it with an iOpener. Heating it will soften the adhesive and minimize the risk of tearing the cable.
  39. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 39, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 39, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 39, afbeelding 3 van 3
    • Insert the tip of a spudger under the battery-side portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
  40. MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 40, afbeelding 1 van 2 MacBook Pro 13" Retina Display Early 2015 Dual Microphone Assembly  Replacement: stap 40, afbeelding 2 van 2
    • Pull the dual microphone cable assembly up and toward the logic board recess to remove it from the upper case.
    • Be very careful not to snag the cable on the screw post in the case or the battery contact board.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
503.085 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.299 handleidingen geschreven
6 opmerkingen
Simply DISABLING the microphones can be done in 3 steps: #1, #2, #25, #26. No need to yank the logic board/fan and all that.
Evan Ralston - Antwoord
Many thanks for preparing / making this brilliant guide available. The mic in my Macbookpro failed for some reason and, using this guide I replaced it with a refurbished spare and saved myself $$. Every single step has been captured with specific additional detail / imagery where needed. It’s scary working with the tiny connectors but this guide gives you confidence it can be done / you can do it.
Nick Cassidy - Antwoord
Nick Cassidy,
Where did you find a replacement? I have looked EVERYWHERE and can not find one.
Thanks!
Frank Vinyard -
破玩意儿,音量开到100听歌儿几个小时后绝逼带去售后换喇叭。
james - Antwoord
This is the usual valuable guide to disassembly. However Steps 8-14 are NOT necessary and create added complication and potential for problems on reassembly. The motherboard can be safely removed with the fan and heatsink attached (make sure to leave the top right 3.6mm fan screw that secures to the motherboard – marked orange in Step 14 – in place). Obviously be careful not to place stress on the fan while it is only held on the one screw but otherwise there is no problem lifting and sliding the board at Step 31. I was able to get at the microphone easily after that and refitting the board was easily done too (making sure cables are not trapped underneath).
I'm slightly at a loss as to why removing the heat sink is deemed necessary unless this guide is based on another where that step is required.
Pete Mackenzie - Antwoord
Sorry, to be clearer (I can't edit my main comment now), Steps 8-13 are not necessary and Step 14 only partially necessary. Only 2 of the screws in Step 14 need be removed – the one circled red and the lower one marked orange.
Pete Mackenzie -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 103
Altijd: 14,856
