Ga door naar hoofdinhoud
MacBook Core Duo Optical Drive Cable Replacement
Wat je nodig hebt
    1. MacBook Core Duo Optical Drive Cable Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Core Duo Optical Drive Cable Replacement: stap 2, afbeelding 1 van 1
      • Lift the battery out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Core Duo Optical Drive Cable Replacement, Memory Cover: stap 3, afbeelding 1 van 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Core Duo Optical Drive Cable Replacement: stap 4, afbeelding 1 van 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Core Duo Optical Drive Cable Replacement, Upper Case: stap 5, afbeelding 1 van 1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Core Duo Optical Drive Cable Replacement: stap 6, afbeelding 1 van 1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Core Duo Optical Drive Cable Replacement: stap 7, afbeelding 1 van 1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Core Duo Optical Drive Cable Replacement: stap 8, afbeelding 1 van 1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Core Duo Optical Drive Cable Replacement: stap 9, afbeelding 1 van 1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Core Duo Optical Drive Cable Replacement: stap 10, afbeelding 1 van 1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      Vraag FixBot
      Voeg opmerking toe
    7. MacBook Core Duo Optical Drive Cable Replacement: stap 11, afbeelding 1 van 1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      Vraag FixBot
      Voeg opmerking toe
    8. MacBook Core Duo Optical Drive Cable Replacement: stap 12, afbeelding 1 van 1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Core Duo Optical Drive Cable Replacement, Optical Drive: stap 13, afbeelding 1 van 1
      • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Core Duo Optical Drive Cable Replacement: stap 14, afbeelding 1 van 1
      • Remove the two Phillips screws from the front edge of the optical drive.
      • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Core Duo Optical Drive Cable Replacement: stap 15, afbeelding 1 van 1
      • Disconnect the orange optical drive ribbon cable from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Core Duo Optical Drive Cable Replacement: stap 16, afbeelding 1 van 1
      • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Core Duo Optical Drive Cable Replacement: stap 17, afbeelding 1 van 1
      • Disconnect the (once again) newly-revealed hard drive cable.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Core Duo Optical Drive Cable Replacement: stap 18, afbeelding 1 van 1
      • Peel up the foil tape between the fan and the optical drive.
      • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
      Vraag FixBot
      Voeg opmerking toe
    7. MacBook Core Duo Optical Drive Cable Replacement: stap 19, afbeelding 1 van 1
      • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
      Vraag FixBot
      Voeg opmerking toe
    8. MacBook Core Duo Optical Drive Cable Replacement: stap 20, afbeelding 1 van 1
      • Remove the 2.8 mm Phillips screw securing the optical drive.
      • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
      • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
      • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
      Vraag FixBot
      Voeg opmerking toe
    9. MacBook Core Duo Optical Drive Cable Replacement: stap 21, afbeelding 1 van 1
      • Lift the Bluetooth antenna board from the right side of the optical drive.
      Vraag FixBot
      Voeg opmerking toe
      • Deroute the hard drive cable from along the front of the optical drive.
      Vraag FixBot
      Voeg opmerking toe
    10. MacBook Core Duo Optical Drive Cable Replacement: stap 23, afbeelding 1 van 1
      • Lift the front edge of the optical drive and slide it up and out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Core Duo Optical Drive Cable Replacement, Optical Drive Cable: stap 24, afbeelding 1 van 1
      • Peel up the orange tape partially covering the orange optical drive cable.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Core Duo Optical Drive Cable Replacement: stap 25, afbeelding 1 van 1
      • Disconnect the orange cable from the optical drive.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
1Gids Commentaar
This was great to use , I was very impress with this guide to remove my optical drive.
Love it!
Stanley Reyes Jr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 47,897
