Ga door naar hoofdinhoud
MacBook Core Duo Display Replacement
Wat je nodig hebt
  1. MacBook Core Duo Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    Vraag FixBot
    Voeg opmerking toe
  2. MacBook Core Duo Display Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  3. MacBook Core Duo Display Replacement, Memory Cover: stap 3, afbeelding 1 van 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    Vraag FixBot
    Voeg opmerking toe
  4. MacBook Core Duo Display Replacement: stap 4, afbeelding 1 van 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  5. MacBook Core Duo Display Replacement, Upper Case: stap 5, afbeelding 1 van 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
    Vraag FixBot
    Voeg opmerking toe
  6. MacBook Core Duo Display Replacement: stap 6, afbeelding 1 van 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
    Vraag FixBot
    Voeg opmerking toe
  7. MacBook Core Duo Display Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    Vraag FixBot
    Voeg opmerking toe
  8. MacBook Core Duo Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    Vraag FixBot
    Voeg opmerking toe
  9. MacBook Core Duo Display Replacement: stap 9, afbeelding 1 van 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
    Vraag FixBot
    Voeg opmerking toe
  10. MacBook Core Duo Display Replacement: stap 10, afbeelding 1 van 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
    Vraag FixBot
    Voeg opmerking toe
  11. MacBook Core Duo Display Replacement: stap 11, afbeelding 1 van 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
    Vraag FixBot
    Voeg opmerking toe
  12. MacBook Core Duo Display Replacement: stap 12, afbeelding 1 van 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    Vraag FixBot
    Voeg opmerking toe
  13. MacBook Core Duo Display Replacement, Optical Drive: stap 13, afbeelding 1 van 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    Vraag FixBot
    Voeg opmerking toe
  14. MacBook Core Duo Display Replacement: stap 14, afbeelding 1 van 1
    • Remove the two Phillips screws from the front edge of the optical drive.
    • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
    Vraag FixBot
    Voeg opmerking toe
  15. MacBook Core Duo Display Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the orange optical drive ribbon cable from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  16. MacBook Core Duo Display Replacement: stap 16, afbeelding 1 van 1
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    Vraag FixBot
    Voeg opmerking toe
  17. MacBook Core Duo Display Replacement: stap 17, afbeelding 1 van 1
    • Disconnect the (once again) newly-revealed hard drive cable.
    Vraag FixBot
    Voeg opmerking toe
  18. MacBook Core Duo Display Replacement: stap 18, afbeelding 1 van 1
    • Peel up the foil tape between the fan and the optical drive.
    • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
    Vraag FixBot
    Voeg opmerking toe
  19. MacBook Core Duo Display Replacement: stap 19, afbeelding 1 van 1
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    Vraag FixBot
    Voeg opmerking toe
  20. MacBook Core Duo Display Replacement: stap 20, afbeelding 1 van 1
    • Remove the 2.8 mm Phillips screw securing the optical drive.
    • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
    • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
    • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
    Vraag FixBot
    Voeg opmerking toe
  21. MacBook Core Duo Display Replacement: stap 21, afbeelding 1 van 1
    • Lift the Bluetooth antenna board from the right side of the optical drive.
    Vraag FixBot
    Voeg opmerking toe
    • Deroute the hard drive cable from along the front of the optical drive.
    Vraag FixBot
    Voeg opmerking toe
  22. MacBook Core Duo Display Replacement: stap 23, afbeelding 1 van 1
    • Lift the front edge of the optical drive and slide it up and out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  23. MacBook Core Duo Display Replacement, C-Channel: stap 24, afbeelding 1 van 1
    • Two 3 mm Phillips near the right speaker.
    • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
    • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
    Vraag FixBot
    Voeg opmerking toe
  24. MacBook Core Duo Display Replacement: stap 25, afbeelding 1 van 1
    • Lift the right speaker out of its housing and set it to the side.
    Vraag FixBot
    Voeg opmerking toe
  25. MacBook Core Duo Display Replacement: stap 26, afbeelding 1 van 1
    • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
    Vraag FixBot
    Voeg opmerking toe
  26. MacBook Core Duo Display Replacement, Display: stap 27, afbeelding 1 van 1
    • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
    Vraag FixBot
    Voeg opmerking toe
  27. MacBook Core Duo Display Replacement: stap 28, afbeelding 1 van 1
    • Lift up on the black right speaker cable with one hand, and deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
    Vraag FixBot
    Voeg opmerking toe
  28. MacBook Core Duo Display Replacement: stap 29, afbeelding 1 van 1
    • Deroute the silver microphone cable and gray display data cable from the tabs at the bottom of the subwoofer.
    Vraag FixBot
    Voeg opmerking toe
  29. MacBook Core Duo Display Replacement: stap 30, afbeelding 1 van 1
    • Remove the single 3.2 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
    Vraag FixBot
    Voeg opmerking toe
  30. MacBook Core Duo Display Replacement: stap 31, afbeelding 1 van 1
    • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board. (Pull vertically on all three.)
    Vraag FixBot
    Voeg opmerking toe
  31. MacBook Core Duo Display Replacement: stap 32, afbeelding 1 van 1
    • Remove the following 2 screws from the right hinge mount:
    • One 6 mm Phillips on the left side of the hinge mount.
    • One 10 mm Phillips on the right side of the hinge mount.
    • Lift the right hinge mount out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  32. MacBook Core Duo Display Replacement: stap 33, afbeelding 1 van 1
    • Hold the display with one hand while removing the screws from the left hinge mount.
    • Remove the following 3 screws from the left hinge mount:
    • One 6 mm smaller diameter Phillips from the right side.
    • One 6 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
    • Lift the left hinge mount out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  33. MacBook Core Duo Display Replacement: stap 34, afbeelding 1 van 1
    • Grasp the display assembly on either side, and lift it up and out of the computer.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
87 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 88
Altijd: 140,530
