Ga door naar hoofdinhoud
MacBook Air SSD Replacement
Wat je nodig hebt
  1. MacBook Air SSD Replacement, SSD: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
    • The two screws on the edge containing the hinge are longer than the others.
    • The eight screws in the corners and remaining edges are shorter.
  2. MacBook Air SSD Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air SSD Replacement: stap 3, afbeelding 1 van 2 MacBook Air SSD Replacement: stap 3, afbeelding 2 van 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air SSD Replacement: stap 4, afbeelding 1 van 1
    • Remove a single T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air SSD Replacement: stap 5, afbeelding 1 van 2 MacBook Air SSD Replacement: stap 5, afbeelding 2 van 2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Austin Blakely
22.283 Reputatie
53 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.786 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 87
Afgelopen 7 dagen: 642
Afgelopen 30 dagen: 3,317
Altijd: 54,373
