Ga door naar hoofdinhoud
MacBook Air 2022 (M2) Trackpad Replacement
Wat je nodig hebt
  1. MacBook Air 2022 (M2) Trackpad Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 3 van 3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Trackpad Replacement, Unfasten the lower case: stap 2, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Unfasten the lower case: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Trackpad Replacement, Insert an opening pick: stap 3, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Insert an opening pick: stap 3, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Insert an opening pick: stap 3, afbeelding 3 van 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Trackpad Replacement, Release the snapping clips: stap 4, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Release the snapping clips: stap 4, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Release the snapping clips: stap 4, afbeelding 3 van 3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 2022 (M2) Trackpad Replacement: stap 5, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement: stap 5, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 2022 (M2) Trackpad Replacement, Release the sliding tabs: stap 6, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Release the sliding tabs: stap 6, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Release the sliding tabs: stap 6, afbeelding 3 van 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Trackpad Replacement, Remove the lower case: stap 7, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Remove the lower case: stap 7, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Remove the lower case: stap 7, afbeelding 3 van 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) Trackpad Replacement, Remove the battery connector cover: stap 8, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
    • Due to screw variances, you may need to use a T4 Torx instead. Keep this in mind whenever you encounter T3 Torx screws during this repair.
  9. MacBook Air 2022 (M2) Trackpad Replacement: stap 9, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement: stap 9, afbeelding 2 van 2
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Trackpad Replacement, Disconnect the battery: stap 10, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Disconnect the battery: stap 10, afbeelding 2 van 2
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 2022 (M2) Trackpad Replacement, Unfasten the trackpad cable cover: stap 11, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the trackpad cable cover.
  12. MacBook Air 2022 (M2) Trackpad Replacement, Access the trackpad press connector: stap 12, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Access the trackpad press connector: stap 12, afbeelding 2 van 2
    • Use a spudger or your fingers to move the trackpad cable cover out of the way so you can access the press connector underneath.
  13. MacBook Air 2022 (M2) Trackpad Replacement, Disconnect the trackpad cable: stap 13, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Disconnect the trackpad cable: stap 13, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry up and disconnect the trackpad cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. MacBook Air 2022 (M2) Trackpad Replacement, Detach the trackpad cable: stap 14, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Detach the trackpad cable: stap 14, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Detach the trackpad cable: stap 14, afbeelding 3 van 3
    • Small bits of mild adhesive secure the trackpad cable to the frame.
    • Gently pull up to detach the trackpad cable from the frame.
    • You can also use an opening pick to loosen the adhesive.
    • During reassembly, you may need to apply new adhesive if the old adhesive is no longer sticky.
  15. MacBook Air 2022 (M2) Trackpad Replacement, Unfasten the trackpad: stap 15, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Unfasten the trackpad: stap 15, afbeelding 2 van 2
    • Use a T5 Torx driver to remove the ten 4 mm screws securing the trackpad.
  16. MacBook Air 2022 (M2) Trackpad Replacement, Separate the trackpad: stap 16, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Separate the trackpad: stap 16, afbeelding 2 van 2
    • Be careful not to lose the six washers resting on the trackpad's screw posts. Without them, your trackpad won't fit properly.
    • Slowly open your MacBook—the trackpad will stay on the display.
  17. MacBook Air 2022 (M2) Trackpad Replacement, Free the trackpad cable: stap 17, afbeelding 1 van 2 MacBook Air 2022 (M2) Trackpad Replacement, Free the trackpad cable: stap 17, afbeelding 2 van 2
    • Carefully feed the trackpad ribbon cable through its slot in the frame.
  18. MacBook Air 2022 (M2) Trackpad Replacement, Remove the trackpad: stap 18, afbeelding 1 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Remove the trackpad: stap 18, afbeelding 2 van 3 MacBook Air 2022 (M2) Trackpad Replacement, Remove the trackpad: stap 18, afbeelding 3 van 3
    • Remove the trackpad.
    • Before installing a new trackpad:
    • Make sure your trackpad has a ribbon cable. If necessary, transfer the old cable, or install the one your new trackpad came with.
    • Make sure that the six washers are in their places on the screw posts.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Spencer Day
61.613 Reputatie
445 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.085 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 107
Afgelopen 30 dagen: 525
Altijd: 6,293
