Ga door naar hoofdinhoud
MacBook Air 2022 (M2) Lower Case Replacement
Wat je nodig hebt
  1. MacBook Air 2022 (M2) Lower Case Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Prepare your Macbook Air for disassembly: stap 1, afbeelding 3 van 3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Lower Case Replacement, Unfasten the lower case: stap 2, afbeelding 1 van 2 MacBook Air 2022 (M2) Lower Case Replacement, Unfasten the lower case: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Lower Case Replacement, Insert an opening pick: stap 3, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Insert an opening pick: stap 3, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Insert an opening pick: stap 3, afbeelding 3 van 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Lower Case Replacement, Release the snapping clips: stap 4, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Release the snapping clips: stap 4, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Release the snapping clips: stap 4, afbeelding 3 van 3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 2022 (M2) Lower Case Replacement: stap 5, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement: stap 5, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement: stap 5, afbeelding 3 van 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 2022 (M2) Lower Case Replacement, Release the sliding tabs: stap 6, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Release the sliding tabs: stap 6, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Release the sliding tabs: stap 6, afbeelding 3 van 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Lower Case Replacement, Remove the lower case: stap 7, afbeelding 1 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Remove the lower case: stap 7, afbeelding 2 van 3 MacBook Air 2022 (M2) Lower Case Replacement, Remove the lower case: stap 7, afbeelding 3 van 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Spencer Day
55.203 Reputatie
408 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 124
Afgelopen 30 dagen: 478
Altijd: 5,427
