Ga door naar hoofdinhoud
MacBook Air 13" Retina Display 2019 Display Replacement
Wat je nodig hebt
  1. MacBook Air 13" Retina Display 2019 Display Replacement, Remove the screws securing the lower case: stap 1, afbeelding 1 van 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Display Replacement, Remove the lower case: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13" Retina Display 2019 Display Replacement, Disconnect the battery: stap 3, afbeelding 1 van 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Display Replacement: stap 4, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Retina Display 2019 Display Replacement, Disconnect the antenna bar: stap 5, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement, Disconnect the antenna bar: stap 5, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  6. MacBook Air 13" Retina Display 2019 Display Replacement: stap 6, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Display Replacement: stap 6, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Display Replacement: stap 6, afbeelding 3 van 3
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  7. MacBook Air 13" Retina Display 2019 Display Replacement: stap 7, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement: stap 7, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  8. MacBook Air 13" Retina Display 2019 Display Replacement: stap 8, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up the display cable connector.
  9. MacBook Air 13" Retina Display 2019 Display Replacement: stap 9, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.4 mm screws
    • Two 4.5 mm screws
  10. MacBook Air 13" Retina Display 2019 Display Replacement, Remove the antenna bar: stap 10, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Display Replacement, Remove the antenna bar: stap 10, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Display Replacement, Remove the antenna bar: stap 10, afbeelding 3 van 3
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
  11. MacBook Air 13" Retina Display 2019 Display Replacement, Remove the display: stap 11, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement, Remove the display: stap 11, afbeelding 2 van 2
    • Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
  12. MacBook Air 13" Retina Display 2019 Display Replacement: stap 12, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Display Replacement: stap 12, afbeelding 2 van 2
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  13. MacBook Air 13" Retina Display 2019 Display Replacement: stap 13, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Display Replacement: stap 13, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Display Replacement: stap 13, afbeelding 3 van 3
    • Lift the MacBook and carefully rotate the display to a 90 degree angle with the upper case.
    • The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Adam O'Camb
196.299 Reputatie
416 handleidingen geschreven
12 opmerkingen
Thanks a lot for the useful guide! I have found some difficulties removing the antenna bar with this description, since there is no information to remove the 4 screws holding the antenna assembly in place. Additionally the force to remove the antenna is very high and may damage the complete antenna. I have used some angled tweezers to remove it and they came right our without any force.
Another question I have for the display replacement on a 2019 MacBook Air is how to get the true tone function and keyboard backlight working again. I have found no infos for the 2019 Air but some people had the same issue with 2018 and up MacBook Pros. Any suggestions on how I could fix this up? (Already made a SMC and PRAM reset)
Thanks in advance!
Josef G - Antwoord
Thanks for the comments! We’ll fix the missing steps right up!
Arthur Shi -
Those are good questions. I would like to know also.
QuickTech -
May I know where to buy a replacement screen from a reliable supplier ?
Alan Li - Antwoord
Hi Alan, we sell replacement screens in our store.
Adam O'Camb -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 26
Afgelopen 7 dagen: 145
Afgelopen 30 dagen: 710
Altijd: 36,251
