Ga door naar hoofdinhoud
MacBook Air 13" Early 2014 Solid-State Drive Replacement
Wat je nodig hebt
  1. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Koop
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2014 Solid-State Drive Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: stap 3, afbeelding 2 van 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Solid-State Drive: stap 4, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 13" Early 2014 Solid-State Drive Replacement: stap 5, afbeelding 1 van 2 MacBook Air 13" Early 2014 Solid-State Drive Replacement: stap 5, afbeelding 2 van 2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusie
90 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
428.113 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
25 opmerkingen
Fairly straight forward once you get the right screwdrivers. Took me less than 10 minutes.
Jesse Collis - Antwoord
Very simple and straight forward replacement. First-party SSD replacement can be found on ebay (typically removed from parted-out MacBook Airs). Currently they're aren't any third-party parts available.
rickhendricks - Antwoord
Don't forget to re-attach the battery cable before closing up the underside... not that I did or anything ;-/
phil - Antwoord
The Relevant Parts list all has incorrect links. Bait & Switch??
Examples:
"$199.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 256 GB"
Actually supplies: 128GB USED
"$349.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 512 GB"
Actually supplies: 256GB USED
carnthehawks - Antwoord
Whoops! Looks like we didn't update the details on those parts when we updated the part itself, sorry about that!
Sam Goldheart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 28
Afgelopen 7 dagen: 145
Afgelopen 30 dagen: 682
Altijd: 283,214
