Deze vertaling is door een computer gegenereerd en is nog niet door iemand nagekeken. Spreek je deze taal? Bekijk het hier.
Inleiding
Upgrade uw harde schijf voor meer opslagcapaciteit.
Wat je nodig hebt
Video overzicht
Schakel je Mac mini uit, ontkoppel alle kabels en draai hem om.
Steek de Jimmy in de opening tussen de aluminium bovenbehuizing en de onderste kunststof behuizing.
De Jimmy zou na ongeveer 1 cm weerstand moeten voelen.
Knijp de twee borgarmen voorzichtig naar elkaar toe en til de AirPort-antenne van de bevestigingspunten.
Verwijder de twee kruiskopschroeven die de zijkant van de harde schijf aan de interne omlijsting bevestigen.
Volg deze instructies in omgekeerde volgorde om uw apparaat weer in elkaar te zetten.
548 andere personen hebben deze handleiding voltooid.
17Gids Commentaar
I seemed to succeed - until I discovered my optical drive had broken. Disks do not mount, after some tries they eject. There was a LOT of dust inside my Mini, I think some got in the optical drive. A cleaning DVD and compressed gas didn't fix it. I wonder if it would be wise to seal the opening to the optical drive -- certainly before cleaning.
This was a failure for me, even though the memory and drive change went well.
Can't fault this guide.
* if you don't have a putty knife & you don't mind some scratches, a thin butter knife will do the trick for getting the case off.
*if you plan to replace hdd with an ssd - you may need to rejig some of the internal wires that run around the edges of the hdd/ssd: after I installed the ssd, and returned the wires to the tight track around the side and socket port end of the ssd, and turned the machine back on, there was a high pitch interference noises coming out the internal speaker every time the drive was active.
The solution: make sure the speaker wire isn't where it's *supposed* to be! There are three sets of wires, include the speaker pair. I reversed the positioning of these with respect to the SSD, i.e. I moved the speaker pair to be furthest away from the SSD, and *didn't* tuck them back in under the plastic lip beside the ssd connector port. I turned it back on, and no more high frequency whining whenever the drive is active
I upgraded my 2007 A1176 Mac Mini with a 2 TB M9T drive that I broke out of Seagate Backup Plus Ext. HD and increased my RAM from 2 GB to 3 GB! Success!
Be very careful with the audio cable removal the ZIF cable lock is VERY DELICATE!!!
