Ga door naar hoofdinhoud
Logitech Webcam Pro 9000 USB Connection Replacement
Wat je nodig hebt
  1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: stap 1, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech Webcam Pro 9000 USB Connection Replacement: stap 2, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Connection Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: stap 3, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech Webcam Pro 9000 USB Connection Replacement: stap 4, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Connection Replacement: stap 4, afbeelding 2 van 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Cory Davis
236 Reputatie
4 handleidingen geschreven
Cal Poly, Team 12-34, Amido Spring 2013 Lid van Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Leden
16 handleidingen geschreven
1Gids Commentaar
what is the connector called
Anirudh Krishnan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 2,498
