Ga door naar hoofdinhoud
Logitech UE Megaboom 4 Charging Port Replacement
Wat je nodig hebt
  1. Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: stap 1, afbeelding 1 van 3 Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: stap 1, afbeelding 2 van 3 Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: stap 1, afbeelding 3 van 3
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Place the end of a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
    Vraag FixBot
  2. Logitech UE Megaboom 4 Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Pull the bottom end of the speaker off and place it aside.
    • Once the glued seal is broken you will be able to pull it off with your hands.
    Vraag FixBot
  3. Logitech UE Megaboom 4 Charging Port Replacement: stap 3, afbeelding 1 van 3 Logitech UE Megaboom 4 Charging Port Replacement: stap 3, afbeelding 2 van 3 Logitech UE Megaboom 4 Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
    • The inside components will begin to slide out of the top from the mesh casing.
    Vraag FixBot
  4. Logitech UE Megaboom 4 Charging Port Replacement: stap 4, afbeelding 1 van 1
    • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
    Vraag FixBot
  5. Logitech UE Megaboom 4 Charging Port Replacement, Charging Port: stap 5, afbeelding 1 van 1
    • Remove the cover from the USB-C charging port end of the device.
    • The port should be visible from the outside.
    Vraag FixBot
  6. Logitech UE Megaboom 4 Charging Port Replacement: stap 6, afbeelding 1 van 3 Logitech UE Megaboom 4 Charging Port Replacement: stap 6, afbeelding 2 van 3 Logitech UE Megaboom 4 Charging Port Replacement: stap 6, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the I/O board inside the speaker's end cover.
    • Set the screws aside for reassembly.
    • Remove the black plastic bracket from the top of the I/O board.
    Vraag FixBot
  7. Logitech UE Megaboom 4 Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Remove the board with the charging port from the inside cover.
    • Take note of the charging port placement for reassembly.
    Vraag FixBot
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2Gids Commentaar
Hi, where dit you find the replacement?
Greets
siemen van camp - Antwoord Deel
Same question here, wehre did you find the charging board replacement?
cheers
bohemianmarine1 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 308
