Ga door naar hoofdinhoud
Logitech MX Ergo Battery Replacement
Wat je nodig hebt
  1. Logitech MX Ergo Battery Replacement, Power off the mouse: stap 1, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Power off the mouse: stap 1, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Power off the mouse: stap 1, afbeelding 3 van 3
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Ergo Battery Replacement, Remove the cover: stap 2, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement, Remove the cover: stap 2, afbeelding 2 van 2
    • Remove the magnetic cover by pulling it away from the bottom mouse half.
  3. Logitech MX Ergo Battery Replacement, Remove the case screws: stap 3, afbeelding 1 van 1
    • Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
  4. Logitech MX Ergo Battery Replacement, Remove the trackball: stap 4, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Remove the trackball: stap 4, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Remove the trackball: stap 4, afbeelding 3 van 3
    • Insert a spudger into the hole on the bottom of the mouse, located under the trackball.
    • Use the spudger to push the trackball out of its recess.
    • Remove the trackball.
  5. Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: stap 5, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: stap 5, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Unhinge the plastic clips: stap 5, afbeelding 3 van 3
    • There are clips all around the perimeter of the mouse case holding the two halves together.
    • Insert an opening pick into the gap on the right side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip.
  6. Logitech MX Ergo Battery Replacement: stap 6, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement: stap 6, afbeelding 2 van 2
    • Slide the opening pick to the lower right side of the mouse.
  7. Logitech MX Ergo Battery Replacement: stap 7, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement: stap 7, afbeelding 2 van 2
    • Slide the opening pick to the bottom side of the mouse.
    • Rotate the opening pick about 30 degrees to unhinge the plastic clip on the bottom end of the mouse.
  8. Logitech MX Ergo Battery Replacement: stap 8, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement: stap 8, afbeelding 2 van 2
    • Slide the opening pick to the center of the left side next to the recess of the trackball.
    • Rotate the opening pick to unhinge the remaining plastic clip.
  9. Logitech MX Ergo Battery Replacement, Create access: stap 9, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Create access: stap 9, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Create access: stap 9, afbeelding 3 van 3
    • Don't completely separate the two halves yet—they're still tethered together by a delicate cable.
    • For better access, place the top half of the mouse to the left of the lower half of the mouse.
  10. Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: stap 10, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: stap 10, afbeelding 2 van 2
    • Use the pointed end of a spudger to gently lift the left side of the black sliding lock on the interconnect cable socket until it stops.
  11. Logitech MX Ergo Battery Replacement: stap 11, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement: stap 11, afbeelding 2 van 2
    • Use the pointed end of a spudger to gently lift the right side of the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
  12. Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: stap 12, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: stap 12, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: stap 12, afbeelding 3 van 3
    • Remove the top half of the mouse.
  13. Logitech MX Ergo Battery Replacement, Disconnect the battery: stap 13, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement, Disconnect the battery: stap 13, afbeelding 2 van 2
    • Use the pointed end of a spudger to push the battery connector up and out of its socket.
  14. Logitech MX Ergo Battery Replacement, Pry out the battery: stap 14, afbeelding 1 van 3 Logitech MX Ergo Battery Replacement, Pry out the battery: stap 14, afbeelding 2 van 3 Logitech MX Ergo Battery Replacement, Pry out the battery: stap 14, afbeelding 3 van 3
    • Insert the long edge of an opening pick between the battery and its housing at the side opposite the battery cable.
    • Push the opening pick under the battery and lift up to pry the battery off of its housing.
    • Make sure you push underneath the battery and not into it. Don't bend or deform the battery.
  15. Logitech MX Ergo Battery Replacement, Lift out the battery: stap 15, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement, Lift out the battery: stap 15, afbeelding 2 van 2
    • Use you fingers to lift the battery out of its housing.
  16. Logitech MX Ergo Battery Replacement, Remove the battery: stap 16, afbeelding 1 van 2 Logitech MX Ergo Battery Replacement, Remove the battery: stap 16, afbeelding 2 van 2
    • Use your fingers to carefully pull the cable out of the socket.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • It is likely you can reuse the old adhesive with the new battery. If you wish to replace the adhesive instead, remove the old adhesive and wipe away any adhesive residue with a lint-free cloth and high-concentration isopropyl alcohol.
    • Follow this guide to install new precut adhesive.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
15 andere personen hebben deze handleiding voltooid.
Adriana Zwink
56.210 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.430 handleidingen geschreven
7 opmerkingen
This guide is fantastic! It was super easy to fix! Thanks!
Corey Trueman - Antwoord
Thank you for this !! Visited this site before for other tutorials you guys are great. This was easy to follow worked good for me.
DJSan - Antwoord
Its a very thorough explinations and guide except the most important point.
Where to buy the new replacement battery.
Jacob Bornman - Antwoord
Those are very well-done instructions. The new battery installation went very well. Thanks for the help.
Lyle Ellingson - Antwoord
hi where did you buy the battery?
Yanna -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 298
Altijd: 15,112
