Ga door naar hoofdinhoud
Logitech M275 Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech M275 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 2 van 3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 3 van 3
    • Flip the mouse over.
    • With your fingers, gently press down and remove the battery cover.
    • Remove the battery and the USB receiver from the mouse.
  2. Logitech M275 Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 Logitech M275 Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
    • Remove the sticker at the bottom of the battery compartment.
    • Use a Phillips screwdriver to remove the single screws at the bottom of the battery compartment.
  3. Logitech M275 Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the top half of the mouse cover.
  4. Logitech M275 Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech M275 Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger or screwdriver to carefully apply upward pressure around each side of the circuit board until the whole piece slides out of the bottom.
  5. Logitech M275 Scroll Wheel Replacement: stap 5, afbeelding 1 van 1
    • Using a soft cloth, gently remove dust and small debris.
  6. Logitech M275 Scroll Wheel Replacement: stap 6, afbeelding 1 van 3 Logitech M275 Scroll Wheel Replacement: stap 6, afbeelding 2 van 3 Logitech M275 Scroll Wheel Replacement: stap 6, afbeelding 3 van 3
    • Carefully remove the wheel from its axis and replace it with the new wheel.
  7. Logitech M275 Scroll Wheel Replacement: stap 7, afbeelding 1 van 3 Logitech M275 Scroll Wheel Replacement: stap 7, afbeelding 2 van 3 Logitech M275 Scroll Wheel Replacement: stap 7, afbeelding 3 van 3
    • Ensure that the new scroll wheel is aligned with the encoder.
    • Make sure that the new scroll wheel spins and clicks into place.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Adrianna Doan
145 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-4, Whithaus Spring 2025 Lid van UC Davis, Team 2-4, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G4
3 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 63
Altijd: 463
