Ga door naar hoofdinhoud
Logitech M100 Switch Replacement
Wat je nodig hebt
    1. Logitech M100 Switch Replacement, Switches: stap 1, afbeelding 1 van 1
      • Disconnect the mouse from any devices before attempting to remove any parts or starting the repair.
      • Flip your mouse over so the bottom is facing up.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech M100 Switch Replacement: stap 2, afbeelding 1 van 1
      • Use a small Phillips #00 screwdriver to remove the single screw at the bottom of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech M100 Switch Replacement: stap 3, afbeelding 1 van 2 Logitech M100 Switch Replacement: stap 3, afbeelding 2 van 2
      • Turn your mouse over so it is facing right side up.
      • Use a spudger or your hands to carefully separate the top from the bottom housing.
      • It's important to remove the top housing while leaving the bottom in place, as the scroll wheel and other internal components may fall out otherwise.
      Vraag FixBot
      Voeg opmerking toe
    4. Logitech M100 Switch Replacement: stap 4, afbeelding 1 van 1
      • Remove the external cable from the slot at the front of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    5. Logitech M100 Switch Replacement: stap 5, afbeelding 1 van 3 Logitech M100 Switch Replacement: stap 5, afbeelding 2 van 3 Logitech M100 Switch Replacement: stap 5, afbeelding 3 van 3
      • Remove the circuit board from the mouse by pushing down at the back and lifting up at the front.
      Vraag FixBot
      Voeg opmerking toe
    6. Logitech M100 Switch Replacement: stap 6, afbeelding 1 van 2 Logitech M100 Switch Replacement: stap 6, afbeelding 2 van 2
      • Lift the scroll wheel from the board.
      • There should be a total of four parts that make up the scroll wheel.
      Vraag FixBot
      Voeg opmerking toe
    7. Logitech M100 Switch Replacement: stap 7, afbeelding 1 van 1
      • Pull the USB cable away from the connector in the same direction as the individual wires to remove it from the motherboard.
      • This step may prove difficult with just your hands. Use a spudger if you need to.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Vraag FixBot
      Voeg opmerking toe
    8. Logitech M100 Switch Replacement: stap 8, afbeelding 1 van 1
      • Find a suitable method to hold the circuit board in place so you don't have to hold it in your hands.
      • Use a small vice to keep it in place or helping hands for this next step.
      Vraag FixBot
      Voeg opmerking toe
    9. Logitech M100 Switch Replacement: stap 9, afbeelding 1 van 3 Logitech M100 Switch Replacement: stap 9, afbeelding 2 van 3 Logitech M100 Switch Replacement: stap 9, afbeelding 3 van 3
      • Use a soldering iron to heat the solder points securing both switches, and remove the switches using tweezers.
      • The soldering iron and the solder holding the switch in place will be very hot and can burn you.
      Vraag FixBot
      Voeg opmerking toe
    10. Logitech M100 Switch Replacement: stap 10, afbeelding 1 van 3 Logitech M100 Switch Replacement: stap 10, afbeelding 2 van 3 Logitech M100 Switch Replacement: stap 10, afbeelding 3 van 3
      • Replace each switch and solder it to the circuit board.
      • The soldering wire may conduct heat up to the hand holding it.
      • Be sure to work in a well ventilated space as the solder may emit smoke.
      • You can use tape to hold the switch in place while soldering.
      Vraag FixBot
      Voeg opmerking toe
    11. Logitech M100 Switch Replacement: stap 11, afbeelding 1 van 2 Logitech M100 Switch Replacement: stap 11, afbeelding 2 van 2
      • Reassemble the mouse by following steps 2-7 in reverse order.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Congratulations, you have now replaced the clickers on your mouse and can continue using it!
Diego De La Fuente
211 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 7-2, Grodsky Spring 2024 Lid van CSU Los Angeles, Team 7-2, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G2
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 62
Altijd: 1,178
