Inleiding
It is recommended that you have the iFixit ProTech toolkit and have already taken out the motherboard and taken apart the case.
Wat je nodig hebt
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Gereedschap gebruikt in deze stap:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
4 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Hey will beat buy honor a warrenty
so where can i buy the screen!!!!
