Ga door naar hoofdinhoud
Logitech G903 Mouse Feet Replacement
Wat je nodig hebt
  1. Logitech G903 Mouse Feet Replacement, Heat the mouse foot: stap 1, afbeelding 1 van 1
    • If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and apply it to the bottom mouse foot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage.
  2. Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 1 van 3 Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 2 van 3 Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: stap 2, afbeelding 3 van 3
    • Slide an opening pick under an edge of the bottom mouse foot.
    • Go slowly, and make sure the pick is underneath both the foot and its adhesive layer if you want to reuse the foot. It's easy to separate the foot from its adhesive.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide the pick under the rest of the foot until you can lift it off the mouse.
    • Remove the foot.
  3. Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: stap 3, afbeelding 1 van 3 Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: stap 3, afbeelding 2 van 3 Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: stap 3, afbeelding 3 van 3
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Peel the adhesive off.
    • Before installing new feet or reinstalling old ones, wipe away any adhesive residue from the mouse with a lint-free cloth and high-concentration isopropyl alcohol.
  4. Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: stap 4, afbeelding 1 van 3 Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: stap 4, afbeelding 2 van 3 Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: stap 4, afbeelding 3 van 3
    • Repeat the previous mouse feet removal procedure to remove:
    • The top mouse foot
    • The two pentagonal mouse feet on the left and right side
    • The two small mouse feet in the center
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
230.403 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.548 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 97
Altijd: 3,159
